Who makes crossram for Eddy headed 500 stroker? #946216
03/08/11 12:45 PM
03/08/11 12:45 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I just bought this car yesterday, and am heading to pick it up on Sunday. Its a 63 Polara vert 383.
However its getting a 600 plus HP 500 stroker that I have sitting here. Now since its getting the max wedge look, which manifold and carbs, as I understand someone makes the manifold that mates to my Edelbrock heads?
63 POLARA 500 CONVERTIBLE
Re: Who makes crossram for Eddy headed 500 stroker? [Re: RUMBLON] #946217
03/08/11 01:23 PM
03/08/11 01:23 PM
A&A transmission.
Rick Allison.
You can buy the whole setup ready to go with lines, carbs and everything through Manciniracing.com.
Re: Who makes crossram for Eddy headed 500 stroker? #946218
03/08/11 01:26 PM
03/08/11 01:26 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Re: Who makes crossram for Eddy headed 500 stroker? [Re: TooMany62s] #946219
03/08/11 02:24 PM
03/08/11 02:24 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Here ya go: http://www.aandatrans.com/Departments/Chrysler-Engine/Intake.aspx
I got my stuff here.
WOW--- Almost 2K for just the manifold???? What carbs did you end up using?
Re: Who makes crossram for Eddy headed 500 stroker? [Re: RUMBLON] #946220
03/08/11 03:11 PM
03/08/11 03:11 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
I saw that reaction coming as soon as I read your first post.
Re: Who makes crossram for Eddy headed 500 stroker? [Re: PorkyPig] #946221
03/08/11 03:26 PM
03/08/11 03:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, figure at least $2500 for the intake, carbs, air cleaners, linkage & fuel lines, $700-$800 for the Maxie exhaust manifolds, and around $700 for the Maxie exhaust, add for mufflers & tailpipes. 500CFM carbs are good for a 440, might want to go to 600s for 500". The Maxies also had relocated voltage regulators, wiring harnesses (on the aprons) and heater hoses.
If you're gonna run a dual-reservoir master cylinder with Maxie manifolds, you'll need a heat shield for it.
You'd also be wise to cut the center hood bracing out before painting the car.
Re: Who makes crossram for Eddy headed 500 stroker? [Re: PorkyPig] #946222
03/08/11 03:27 PM
03/08/11 03:27 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Ya, I was thinking closer to $1300 or so, but I will have to bite the bullet as I want the look!
Re: Who makes crossram for Eddy headed 500 stroker? [Re: RUMBLON] #946223
03/08/11 04:41 PM
03/08/11 04:41 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I'm using two Edelbrock 500's from Mancini. They modify them to put the fuel inlets on the opposite side.
Re: Who makes crossram for Eddy headed 500 stroker? [Re: RUMBLON] #946224
03/08/11 04:51 PM
03/08/11 04:51 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I've seen OE intakes from $800-$1500. Take your time and shop around. Look for the Stage I intakes, they're the cheapest.
Also, most of the maxie repro. parts come from Norm Brady @ Crossram Connection.
Re: Who makes crossram for Eddy headed 500 stroker? [Re: 64Post] #946225
03/08/11 06:00 PM
03/08/11 06:00 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'm no expert on Maxie's, but is the O.P. Talking about Eddy RPM heads? If so, the port sizes won't match an O.E. Maxie cross-ram, will they? Not to mention, if you are really going for the Maxie look, modern budget aluminum heads don't really jive, do they?
Also, we're talking about high-dollar reproduction stuff here to get the full Maxie vibe, but the car in the O.P. Is a convertable, isn't it (???). Don't mean to be a buzz-kill, but I'm having a tough time following this thread without shaking my head a little.... Maybe just me? Flog me if needed.
Re: Who makes crossram for Eddy headed 500 stroker? [Re: StealthWedge67] #946226
03/08/11 07:20 PM
03/08/11 07:20 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
The Eddy ports can be opened to MW size and they can also be painted. Or, the Stealth heads can be used and painted.
Yeah, I'd kinda worry about a 500" torque monster in a vert, too.
Re: Who makes crossram for Eddy headed 500 stroker? [Re: 64Post] #946227
03/08/11 08:14 PM
03/08/11 08:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The A&A intake is available in both standard 440 port size and Maxie port size.
Re: Who makes crossram for Eddy headed 500 stroker? [Re: topside] #946228
03/08/11 08:49 PM
03/08/11 08:49 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
True enough Steve, but you have to pay out the a**...
IMO, if you're using Eddy heads, it's cheaper to open the intake port and use a $1000 intake than to pay $1800 for std port A&A intake -- at least to me.
Re: Who makes crossram for Eddy headed 500 stroker? [Re: 64Post] #946229
03/08/11 11:35 PM
03/08/11 11:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Good point, makes sense, but the bigger ports could be pretty lazy on the street; then again, I don't know or recall what the intended use (or gear/converter/etc) the plan involves.
I haven't been keeping up on the A&A intake pricing; last I saw they were $1395.
Re: Who makes crossram for Eddy headed 500 stroker? [Re: StealthWedge67] #946230
03/10/11 12:05 AM
03/10/11 12:05 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Your not killing my buzz. Im not trying to make a period correct perfect Max wedge car. This car if I build it, will just be the way I wnat it and probably the last car I ever do. I just wanted the crossram look for the engine bay.
I pick it up this saturday and will know more then as what I wanted was to build a balck car with red interior and I actually was looking for a HT or post car. But this is what I found and the wife likes verts. So I wanted that engine bay look. And I have that done motor but once again I am in the quandry of the fact that the car according to many should get done back to original and thats not what I wanted. A mopar moral compass moment.
In any case I thank everyone for the prices and I will wait and see what the future brings.
Re: Who makes crossram for Eddy headed 500 stroker? [Re: RUMBLON] #946231
03/10/11 01:20 AM
03/10/11 01:20 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
$2000 for the manifold is nothing compared to what it's going to cost to do a complete resto-mod on that car. Ask me how I know...
