Six Pack Gurus?
#945844
03/07/11 11:29 PM
03/07/11 11:29 PM
Posts: 228 northeast texas
strokin73cuda
northeast texas
I have a dual plane intake on my car (eddy) now and want to try a single plane. I'm running indy srs mildly ported, best time last year was 6.87@98 1/8th car weighs 3550 w me in it. Where do I get one for a six pack or whats the best way to build one?
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: Six Pack Gurus?
[Re: Cab_Burge]
#945847
03/08/11 10:00 AM
03/08/11 10:00 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
hey Joe, here is a thread on the Indy mod man intake. you may as well get the heads opened to MW if you go this route https://board.moparts.org/ubbthreads/show...part=1&vc=1
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Six Pack Gurus?
[Re: Tommy D]
#945849
03/09/11 05:24 PM
03/09/11 05:24 PM
gtx69
super gas
super gas
Re: Six Pack Gurus?
[Re: Cab_Burge]
#945854
03/10/11 03:32 PM
03/10/11 03:32 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
working on this one
Thats 1 way to fix a 6 bogger - run the Ford carbs with accelerator pumps in the end carbs.
Them ain't no Ford carbs. Those are a set of the original aftermarket six pak carbs for whatever you wanted to put them on They make more power on the engine dyno than the OEM carbs do, even modified by a good carb shop
They may not be FORD carbs, but they sure aren't Mopar (STYLE) carbs. Not with pumps in the end carbs, no vacuum seconday pods, full mechanical throttle linkage, and the fuel inlets on the linkage side. And, yes I'm aware of the accel pump conversion kits for the ends, but that still leaves the fuel inlets on the other side of the carb, like the FORDS.
Free advice and worth every penny... Factory trained Slinky rewinder.........
Re: Six Pack Gurus?
[Re: Evil Spirit]
#945855
03/11/11 04:02 AM
03/11/11 04:02 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
working on this one
The key word is "Holley aftermarket carbs" for sale over the counter for 340,440 six paks and Corvette Tri Power, not for Fords. The Ford carbs where turn around so the fuel bowls would not hit the distributor is what I remember on the 1962 and 1963 406 Ford Tri Power cars I seem to remember some of the 1969 A12 440 6 pak cars having drivers side fuel inlet also, is that true? Any of the real A12 guys on here?
Re: Six Pack Gurus?
[Re: Evil Spirit]
#945856
03/11/11 12:25 PM
03/11/11 12:25 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
working on this one
They ARE Mopar carbs..... Kinda. They were sold by Mopar's Direct Connection back in the day. Check out one of the old catalogues. Excellent performance and drivability AND no idle circuit headaches in the outboards.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Six Pack Gurus?
[Re: Evil Spirit]
#945858
03/11/11 02:34 PM
03/11/11 02:34 PM
jbc426
West Coast, USA
Without seeing the numbers on the carbs, I call them Ford carbs because that is the configuration that Ford ran in STOCK 3x2 form - fuel inlets on the linkage side, mechanical linkage, and accel pumps in ind carbs. Mopar carbs in STOCK form had vacuum pods (and no accel pumps)on the end carbs, and the fuel inlets on the pod sides. I guess I should have known to say Ford TYPE or Mopar TYPE to eliminate the nit-picking and hair spliting.
Yah, well....they're Holley carbs, and Ford is a four-letter-word around these parts. Besides, it's those Chevy carbs that had the vacuum pods and such on them. Mechanical's rule...vacuum sucks!!!
Re: Six Pack Gurus?
[Re: jbc426]
#945859
03/12/11 12:35 AM
03/12/11 12:35 AM
Evil Spirit
Newport, Mi
You CAN'T be saying that Mopars didn't run vacuum operated end carbs
Re: Six Pack Gurus?
[Re: Evil Spirit]
#945860
03/12/11 04:20 AM
03/12/11 04:20 AM
jbc426
West Coast, USA
You are correct. I was mocking the reference to the mechanical carbs being referred to as Ford carbs, by referring to the vacuum carbs as Chevy carbs; all while attempting to point out that they are all just Holley carbs. Referencing either kind as one brand or another is ....folly, cuz they're all simply Holley.
Re: Six Pack Gurus?
[Re: jbc426]
#945861
03/12/11 12:51 PM
03/12/11 12:51 PM
Evil Spirit
Newport, Mi
You musta skipped over this part out of a post several posts ago - I guess I should have known to say Ford TYPE or Mopar TYPE to eliminate the NITPICKING and HAIR SPLITTING. I never said they weren't Holley BRAND, I was only referring the kinds of cars the different TYPES were usually associated to.
Re: Six Pack Gurus?
[Re: Cab_Burge]
#945862
03/12/11 01:40 PM
03/12/11 01:40 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I have a dual plane intake on my car (eddy) now and want to try a single plane. I'm running indy srs mildly ported, best time last year was [Email]6.87@98[/Email] 1/8th car weighs 3550 w me in it. Where do I get one for a six pack or whats the best way to build one?
There are three options that I'm aware of, Indy two piece with the six pak lid, custom made sheet metal intake and the last is the old Weiand Super Stock cast aluminum two piece semi tunnel ram six pak intakes.IHTHs
You're forgetting one Cab, the Eldebrock STR-14 with the six pack top.
Re: Six Pack Gurus?
[Re: Evil Spirit]
#945863
03/12/11 01:40 PM
03/12/11 01:40 PM
jbc426
West Coast, USA
Actually, it was more like a leap with a quick spin and a triple-2-barrel blast.
Sorry, I got excited, just had coffee, and am going out to test some bigger jets I just installed in my....Holley's.
