2.20 int. in a eddy rpm head? #945722
03/07/11 09:56 PM
03/07/11 09:56 PM
sc
tjmarcus1 Offline OP
sc
who's done it and how did it work? i am thinking about it
Re: 2.20 int. in a eddy rpm head? [Re: tjmarcus1] #945723
03/07/11 11:35 PM
03/07/11 11:35 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Indy sells a 2.19 for a eddy rpm
Re: 2.20 int. in a eddy rpm head? [Re: 6PACMAC] #945724
03/07/11 11:39 PM
03/07/11 11:39 PM
sc
sc
i have 2.19's in them, but i need new valves
Re: 2.20 int. in a eddy rpm head? [Re: tjmarcus1] #945725
03/08/11 08:34 AM
03/08/11 08:34 AM
Brisbane Australia
572B1 Online content
572B1  Online Content
Brisbane Australia
If you wan't to find the limit of your cylinder heads, contact Jeff from Modern cylinder heads. This is right up his alley.
Re: 2.20 int. in a eddy rpm head? [Re: 572B1] #945726
03/09/11 02:35 PM
03/09/11 02:35 PM
sc
sc
Re: 2.20 int. in a eddy rpm head? [Re: tjmarcus1] #945727
03/09/11 02:49 PM
03/09/11 02:49 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
From what I've seen, IF the port is revised to use the bigger valve it'll probably be worth about 5 cfm over the standard 2.14". On a small-port head like a Performer RPM, it's not like the valve size is corking up the intake runner.
Re: 2.20 int. in a eddy rpm head? [Re: BradH] #945728
03/10/11 02:37 AM
03/10/11 02:37 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I ported on a set of RPM heads and ran a 2.250 valve with max wedge port size. It flowed an unsteady 345@ .750". This was preliminary testing and I know I could have steadied things up, but I had jobs that were paying that required my attention and my (ex) boss wasn't all that good at paying me anyway.
Point being, if you have a large enough bore to take advantage of it and you open up the port, the larger valve will help. Otherwise it can actually impede airflow because the chamber and cylinder needs to be far enough away that air can get around the valve.
