Drag Pak Engines #945681
03/07/11 09:16 PM
03/07/11 09:16 PM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
For those of you in the know... need some engine particulars
what heads are on a 5.7 drag pak engine?
Are they new eagle heads or a 6.1 head, or what?
What pistons are used in a stock drag pack? Diamond? JE?
Do they come with a solid or hydraulic roller? If solid what rocker gear?
Would a 96 dakota with a 5.7 hemi be able to fit in SS/TA or GT class?
thanks in advance...Justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Drag Pak Engines [Re: wldtm] #945682
03/07/11 10:32 PM
03/07/11 10:32 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
I don't much about the specifics of the engine but I can tell you that these engines are legal for the TA and GT truck classes. With the minimum weight in TA I would think this engine would be better suited for TB which is a SB only designation if my memory serves me right. The downside to TA and TB is that they are carb only classes. TA mandates an 850cfm carb and TB mandates a 750cfm carb and both classes have an 8.5lbs per cube weight factor. I forget what the minimum weights are but other than the carbs, you can pretty much run whatever else you want. No rotating assembly restraints or head restraints but you will have to kick some rpms and make some good power in these classes to run well as the current standard for both of those is 9.00 and faster for the most part(at least 9.20's). In the GT truck classes you would run the engine according to stock specs within NHRA guidelines except that you aren't limited in vavletrain or intake manifold. You will however have certain restrictions to maintain. C.R., a certain port volume, stock sized valves, standard efi system, spec rods, and spec pistons, all of which have to mach certain specs and weight. It sounds more technical than it is but those are just some of things you have to face in putting together the engine. On the bright side of things though, the GT HP ratings for the 5.7 and 6.1 are untouched and both ratings are softer than a brownie, especially the 5.7. 305 HP rating would put you on the minimum weight for most of the class designations. You could probably run GT/TC or TD and still run on the minimum weight. Its definitely got some potential and wish you nothing but blessing going forward. I personally hope you decide to run TA as I would like to see what these engine could do when transformed into a high winding rpm all out modified style engine.
NHRA Accepted product list:
http://www.nhra.com/userfiles/file/NHRAAcceptedProducts.pdf
NHRA 09 and 10 Blueprint Specs:
http://www.nhra.net/tech_specs/engine/blueprints/CHRY-09.rtf
http://www.nhra.net/tech_specs/engine/blueprints/CHRY-10.rtf
Current GT factors:
305 for the 5.7
385 for the 6.1
275 for the 360
Adriel Paradise
Substation Design Engineer III
Re: Drag Pak Engines [Re: Adrielp] #945683
03/07/11 11:20 PM
03/07/11 11:20 PM
Dayton, Ohio
W
wldtm Offline OP
wldtm  Offline OP
W
Dayton, Ohio
Thanks for an informative post. I think I like the idea of the GT class for now. I personally like the 5.7 for the hp factor.
So lets say the 5.7 gets factored because of a drag pack car blows away the index (as we have seen in the past). This will then raise the factor for my engine in GT too? Correct?
thanks again for the input...justin
Re: Drag Pak Engines [Re: wldtm] #945684
03/08/11 12:08 AM
03/08/11 12:08 AM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
I am going to build a 5.7 for GT and can offer the following. I have been told by NHRA that if an engine has fresh air (scoop) in its normal class then it has to be used in a fresh air car in GT. The opposite is also true, a non fresh air car can't be used in a fresh air car. So the Drag Pak engines in GT has to be in a scooped car such as a 68 hemi Cuda or Dart. Since the rule book says that the GT truck class has the same rules as the GT car rules with the exceptions listed in the GT truck section it would look like the Drag Pak is not legal in a truck. Don't know of any truck with fresh air. I'm using a 68 AH type Cuda.
As for the 5.7 and 6.1 engine, the 2009 engines both came with the 6.1 SRT8 heads with slightly larger valves, casting#5037369AA. 2.10 and 1.60 valves. The pistons are 12.7-1 Diamond #46191. Has a hyd roller with .584 and .552 lift. Non adjustable rockers.
I haven't started my engine yet. Have had some shocks on parts. Jesel drop in roller lifters for $3200 and rockers for $4800. Harland Sharp does have a set of rockers for $1800 that are adjustable. Think the rods are Scat with ARP bolts. Manley and K1 make approved rods.
As for the HP factors, the SS and GT factors are seperate so it would take a GT car to hit the GT factor, not a SS car.
Good luck with whatever direction you go.
Re: Drag Pak Engines [Re: wldtm] #945685
03/08/11 12:12 AM
03/08/11 12:12 AM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Actually you don't. If you look at the classification guide you will see that the GT factors are separate from the other SS categories so until you or someone with your combo in GT bust up the index, you don't have to worry. I think the 360 has been hit a couple times as Mark Nowicki in the Northeast upgraded his 360 to the dragpak version and has been loving it. The stock cars are the only ones having factoring trouble right now any way. No Super Stock DragPaks have been to the track yet. MR2Performance built a couple of Super Stock versions and one of those cars is teamed with Rock Haas and they have been doing to some engine development but it has yet to hit the track. I think their searching for more ways to make power.
Adriel Paradise
Re: Drag Pak Engines [Re: Stewart] #945686
03/08/11 01:06 AM
03/08/11 01:06 AM
Locomotion Offline
Locomotion  Offline
Do some more research. Neither Mark Nowicki and his Avenger nor the '70 Duster that is run out of the Teuton stable have fresh air scoops. They both have the 5.9 Magnum Drag Pak engines in SS/GT. I know of other non-air combos being built also.
Re: Drag Pak Engines [Re: Locomotion] #945687
03/08/11 08:35 AM
03/08/11 08:35 AM
Lebanon,IN
mr2performance Offline
Lebanon,IN
Mike Wagner has a 6.1 MPR built challenger superstocker. I'm building a 5.7 DRAG PAK challenger superstocker right now as well as dropping a 5.7 Superstock dragpak engine in a SS/AH Cuda. Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Drag Pak Engines [Re: mr2performance] #945688
03/08/11 07:43 PM
03/08/11 07:43 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Steve Couch debuted his 5.9 Drag Pak last year in SS/JA, but I think he is really going to run it as a Stocker.
Re: Drag Pak Engines [Re: mr2performance] #945689
03/08/11 11:01 PM
03/08/11 11:01 PM
SC304 Offline
SC304  Offline
Mike wagners 6.1 is ready for dyno this week
Here are some progress photos.
Stock Drag Pak head versus preparing for Jesel rockers and lifters
Re: Drag Pak Engines [Re: SC304] #945690
03/08/11 11:02 PM
03/08/11 11:02 PM
SC304 Offline
SC304  Offline
next phase is clearing head for jesel rocker base plate
Re: Drag Pak Engines [Re: SC304] #945691
03/08/11 11:05 PM
03/08/11 11:05 PM
SC304 Offline
SC304  Offline
Jesel rockers installed with Trend double taper 7/16 push rods.
Re: Drag Pak Engines [Re: SC304] #945692
03/08/11 11:06 PM
03/08/11 11:06 PM
SC304 Offline
SC304  Offline
Assembled motor
Re: Drag Pak Engines [Re: SC304] #945693
03/08/11 11:11 PM
03/08/11 11:11 PM
SC304 Offline
SC304  Offline
Assembled motor
Assembled motor with Billet Moroso Valve covers
Re: Drag Pak Engines [Re: SC304] #945694
03/08/11 11:17 PM
03/08/11 11:17 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
WOW..... Mike that is a really a sweet piece.
Re: Drag Pak Engines [Re: SC304] #945695
03/08/11 11:24 PM
03/08/11 11:24 PM
SC304 Offline
SC304  Offline
Assembled motor
Next we need to build 5.7 and 6.4 just in case. LOL
Gonna change a few things after lessons learned building 6.1.
This project has been a long time coming and would not have been possible without my partners Dave,Kyle and Rock. Their dedication to this engine program and this entire Super Stock Challenger Project while I am on the road working is unsurpassed.
" In Case Your Wondering"
They know what it means.
Thanks Guys
Re: Drag Pak Engines [Re: SC304] #945696
03/08/11 11:40 PM
03/08/11 11:40 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
how does the jessel oil the valvetrain?
is jessel the only one making a solid lifter?
looks very nice and expensive
Re: Drag Pak Engines [Re: 340RICK] #945697
03/08/11 11:41 PM
03/08/11 11:41 PM
SC304 Offline
SC304  Offline
Thanks Rick
Re: Drag Pak Engines [Re: sixpackgut] #945698
03/08/11 11:44 PM
03/08/11 11:44 PM
SC304 Offline
SC304  Offline
is that a solid roller cam motor?
We oil thru the Push Rods as expected.
Yes to Solid Roller by Comp Cams, Jesel Dog Bone Lifters modified by Kyle to oil properly.
Expensive ? Oh hell yeah, but be quiet my wife might be watching??
Im afraid to add up the cost.
Re: Drag Pak Engines [Re: SC304] #945699
03/08/11 11:59 PM
03/08/11 11:59 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Nice Bullet!!!! I assume the Jesel allows you to use longer valves & have more installed height for valve springs?
Re: Drag Pak Engines [Re: SC304] #945700
03/09/11 12:43 AM
03/09/11 12:43 AM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Mr. Mike, I've been waiting to see what this car can do for while and the hard work that you guys have done is very impressive. Look forward to seeing it at the track and hopefully, you guys can make it to Belle Rose(my fingers are crossed lol).
And in regards to the cost, we all know the exact number, we just remain in denial to make ourselves fill better. But at the end of the day its about having fun and learning knew things. You never stop learning lol.
PS: I pray nothing but many blessings over the project going forward.
Adriel Paradise
