Drag Pak Engines
#945681
03/07/11 09:16 PM
03/07/11 09:16 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
For those of you in the know... need some engine particulars
what heads are on a 5.7 drag pak engine?
Are they new eagle heads or a 6.1 head, or what?
What pistons are used in a stock drag pack? Diamond? JE?
Do they come with a solid or hydraulic roller? If solid what rocker gear?
Would a 96 dakota with a 5.7 hemi be able to fit in SS/TA or GT class?
thanks in advance...Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
Re: Drag Pak Engines
[Re: wldtm]
#945682
03/07/11 10:32 PM
03/07/11 10:32 PM
Posts: 577 Arkansas
Adrielp
Arkansas
I don't much about the specifics of the engine but I can tell you that these engines are legal for the TA and GT truck classes. With the minimum weight in TA I would think this engine would be better suited for TB which is a SB only designation if my memory serves me right. The downside to TA and TB is that they are carb only classes. TA mandates an 850cfm carb and TB mandates a 750cfm carb and both classes have an 8.5lbs per cube weight factor. I forget what the minimum weights are but other than the carbs, you can pretty much run whatever else you want. No rotating assembly restraints or head restraints but you will have to kick some rpms and make some good power in these classes to run well as the current standard for both of those is 9.00 and faster for the most part(at least 9.20's). In the GT truck classes you would run the engine according to stock specs within NHRA guidelines except that you aren't limited in vavletrain or intake manifold. You will however have certain restrictions to maintain. C.R., a certain port volume, stock sized valves, standard efi system, spec rods, and spec pistons, all of which have to mach certain specs and weight. It sounds more technical than it is but those are just some of things you have to face in putting together the engine. On the bright side of things though, the GT HP ratings for the 5.7 and 6.1 are untouched and both ratings are softer than a brownie, especially the 5.7. 305 HP rating would put you on the minimum weight for most of the class designations. You could probably run GT/TC or TD and still run on the minimum weight. Its definitely got some potential and wish you nothing but blessing going forward. I personally hope you decide to run TA as I would like to see what these engine could do when transformed into a high winding rpm all out modified style engine.
NHRA Accepted product list: http://www.nhra.com/userfiles/file/NHRAAcceptedProducts.pdf
NHRA 09 and 10 Blueprint Specs: http://www.nhra.net/tech_specs/engine/blueprints/CHRY-09.rtf
http://www.nhra.net/tech_specs/engine/blueprints/CHRY-10.rtf
Current GT factors: 305 for the 5.7 385 for the 6.1 275 for the 360
Adriel Paradise Substation Design Engineer III
[Re: Adrielp]
#945683
03/07/11 11:20 PM
03/07/11 11:20 PM
wldtm
Dayton, Ohio
Thanks for an informative post. I think I like the idea of the GT class for now. I personally like the 5.7 for the hp factor.
So lets say the 5.7 gets factored because of a drag pack car blows away the index (as we have seen in the past). This will then raise the factor for my engine in GT too? Correct?
thanks again for the input...justin
PM for details
[Re: Stewart]
#945686
03/08/11 01:06 AM
03/08/11 01:06 AM
Posts: 5,894 Florida
Locomotion
I am going to build a 5.7 for GT and can offer the following. I have been told by NHRA that if an engine has fresh air (scoop) in its normal class then it has to be used in a fresh air car in GT. The opposite is also true, a non fresh air car can't be used in a fresh air car. So the Drag Pak engines in GT has to be in a scooped car such as a 68 hemi Cuda or Dart. Since the rule book says that the GT truck class has the same rules as the GT car rules with the exceptions listed in the GT truck section it would look like the Drag Pak is not legal in a truck. Don't know of any truck with fresh air. I'm using a 68 AH type Cuda.
Do some more research. Neither Mark Nowicki and his Avenger nor the '70 Duster that is run out of the Teuton stable have fresh air scoops. They both have the 5.9 Magnum Drag Pak engines in SS/GT. I know of other non-air combos being built also.
[Re: Locomotion]
#945687
03/08/11 08:35 AM
03/08/11 08:35 AM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
Mike Wagner has a 6.1 MPR built challenger superstocker. I'm building a 5.7 DRAG PAK challenger superstocker right now as well as dropping a 5.7 Superstock dragpak engine in a SS/AH Cuda. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: mr2performance]
#945689
03/08/11 11:01 PM
03/08/11 11:01 PM
Posts: 287 Michigan
SC304
Mike wagners 6.1 is ready for dyno this week
Here are some progress photos.
Stock Drag Pak head versus preparing for Jesel rockers and lifters
[Re: SC304]
#945690
03/08/11 11:02 PM
03/08/11 11:02 PM
Posts: 287 Michigan
SC304
next phase is clearing head for jesel rocker base plate
[Re: SC304]
#945691
03/08/11 11:05 PM
03/08/11 11:05 PM
Posts: 287 Michigan
SC304
Jesel rockers installed with Trend double taper 7/16 push rods.
[Re: SC304]
#945692
03/08/11 11:06 PM
03/08/11 11:06 PM
Posts: 287 Michigan
SC304
Assembled motor
[Re: SC304]
#945693
03/08/11 11:11 PM
03/08/11 11:11 PM
Posts: 287 Michigan
SC304
Assembled motor
Assembled motor with Billet Moroso Valve covers
[Re: SC304]
#945695
03/08/11 11:24 PM
03/08/11 11:24 PM
Posts: 287 Michigan
SC304
Assembled motor
Next we need to build 5.7 and 6.4 just in case. LOL Gonna change a few things after lessons learned building 6.1.
This project has been a long time coming and would not have been possible without my partners Dave,Kyle and Rock. Their dedication to this engine program and this entire Super Stock Challenger Project while I am on the road working is unsurpassed. " In Case Your Wondering"
They know what it means.
Thanks Guys
[Re: SC304]
#945696
03/08/11 11:40 PM
03/08/11 11:40 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
how does the jessel oil the valvetrain? is jessel the only one making a solid lifter? looks very nice and expensive
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#945698
03/08/11 11:44 PM
03/08/11 11:44 PM
Posts: 287 Michigan
SC304
is that a solid roller cam motor?
We oil thru the Push Rods as expected.
Yes to Solid Roller by Comp Cams, Jesel Dog Bone Lifters modified by Kyle to oil properly.
Expensive ? Oh hell yeah, but be quiet my wife might be watching?? Im afraid to add up the cost.
[Re: ZIPPY]
#945702
03/09/11 11:39 PM
03/09/11 11:39 PM
wldtm
Dayton, Ohio
GT/TB index is 10.85 10.5 X 305HP = 3202 + 170 driver = 3372 at the scales after a run
so it needs to run 9.60-9.80s to be competitive. Currently an A/SA runs 10.0s (some faster) out of most chally stockers with a 6.1
so i think a 5.7 rated at 305hp Superstocker can get it done at 3372.
any takers?
PM for details
