What size tire will fit once springs have been moved in #945564
03/07/11 07:35 PM
03/07/11 07:35 PM
southern illinois
Y
yellowscamp Offline OP
Y
southern illinois
I just had the rear springs moved inbored even with the frame rails and was wanting to know what size tires are you running,rim and offset. It is on a 71 scamp with a standard width a-body 8-3/4 rearend. The wheel wells have not been modified. If you have any picks that would be great. Thanks.
Re: What size tire will fit once springs have been moved in [Re: yellowscamp] #945565
03/07/11 11:28 PM
03/07/11 11:28 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
with a standard 15x7" rim with 41/2" b/s you can run a 255/60/15.
You could probably fit a custom 15x8" rim with 5 1/2 b/s if you wanted more meat.
Re: What size tire will fit once springs have been moved in [Re: yellowscamp] #945566
03/07/11 11:32 PM
03/07/11 11:32 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You only have an inch more space than you did before, but every inch helps
