Engine painting, what do you do? #945370
03/07/11 06:00 PM
03/07/11 06:00 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
The major parts of my engine will be back from the machine shop soon so the assembly will begin shortly after. So what is the best way to paint the engine? I’m not a novice at this but just want to know if there are any better ways to do this. I’ve always assembled the engine, cleaned it off with lacquer thinner and/or brake cleaner, then rattle canned on the engine paint (Duplicolor Chrysler Orange). It seems to have worked out well and holds up decently.
I’m not going for any Concourse level “correct” look; I’m just painting the assembly. I’ve heard of people spraying the whole engine complete with DP Epoxy, and then painting it with color over that.
Just curious what do you do, and how does it hold up?
Scott
Re: Engine painting, what do you do? [Re: 70Sbird] #945371
03/07/11 09:47 PM
03/07/11 09:47 PM
I'm not a paint guy so I have no opinion on a good paint but I've seen engines painted that have a gloss to them that looks good & obviously there was some care put into it though not everyone wants a glossy finish but I'm just saying. I do my final cleaning w cans of buck fifty starting fluid & drown the surface I am prepping. It gets into nooks and crannies & flushes em out & flashes off in minutes (warm weather) & as you know prep (including cleanliness) is 90% of the game.
Re: Engine painting, what do you do? [Re: RapidRobert] #945372
03/07/11 10:07 PM
03/07/11 10:07 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've heard of guys doing it either way. Hitting it with a primer then car paint seems to work just fine and hold up well. I'm not a fan of the duplicolor hemi orange paint, it's way too thin and takes 1000 coats to cover. Next time I may use some real car paint instead, or maybe try the plastikote engine paints.
Re: Engine painting, what do you do? [Re: DaytonaTurbo] #945373
03/07/11 11:39 PM
03/07/11 11:39 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Well, one of the important things is to gewt the engine oil and greese and as rust free as you can get it. I have used PPG omni epoxy primer...but it doesn't like aluminum unless you use etch primer and let it dry good. You can use Rustoliums 2000 deg. primer let it dry and then you can use automotive acrilic enamial. It seams to hold up well. Don't use any automotive paint that uses strong solvents because it will wrinkle up on you. Hope this helps a little..
Re: Engine painting, what do you do? [Re: DaytonaTurbo] #945374
03/07/11 11:48 PM
03/07/11 11:48 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Daytona Turbo, I may have been mistaken The Plasticoat paint is what I may have used, it seemed like 3 coats and it looked great!
Has anyone tried the Rustoleum engine paint?
Here is what my engine looked like after 7 years and 10,000 miles.
Re: Engine painting, what do you do? [Re: GLR] #945375
03/07/11 11:51 PM
03/07/11 11:51 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used regular car paint with a little hardener mixed in and brushed it on.
Do each part separately then assemble and if needed touch up.
It turned out great with only 2 coats but as to how long it lasts I can;t say as we just built the motor this winter.
Re: Engine painting, what do you do? [Re: WILD BILL] #945376
03/08/11 12:00 AM
03/08/11 12:00 AM
Amherst,NY
challengermike Offline
Amherst,NY
I used regular car basecoat clearcoat paint and it works good.I also paint it in pieces.And i paint all the bolt silver.
Re: Engine painting, what do you do? [Re: challengermike] #945377
03/09/11 02:49 PM
03/09/11 02:49 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
The motor in my Challenger we base coat /clear coated about 16 years ago and it still looks good. The motor in my Dart and plow truck I used I think VHT Hemi orange and they both look good also. I like the VHT as it goes on heavier than the Mopar paint, hence less coats. The 440 is the Challenger one.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Engine painting, what do you do? [Re: 70Sbird] #945378
03/09/11 03:05 PM
03/09/11 03:05 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
We did my 340 in car base/clear about 7 years ago and the friggin' stuff won't come off even now when I want it to. Good prep work is the key.
Re: Engine painting, what do you do? [Re: dustergirl340] #945379
03/09/11 03:16 PM
03/09/11 03:16 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
One of the keys to good adhesion is to wait for a dry day and chase any moisture out of the cast iron with a propane torch.
The sun works good too....when that finally comes back.
Re: Engine painting, what do you do? [Re: 70Sbird] #945380
03/09/11 03:17 PM
03/09/11 03:17 PM
southern illinois
O
ozz383 Offline
ozz383  Offline
O
southern illinois
I just finished my bee engine with the Rustoleum hemi orange it looks good.also used it on my 340 a year ago and it has been driven alot and still looks good. I always prime them before paint, it seems to work for me. ozz
Re: Engine painting, what do you do? [Re: dustergirl340] #945381
03/09/11 03:21 PM
03/09/11 03:21 PM
Berlin, N.J.
abodyjoe Online content
abodyjoe  Online Content
Berlin, N.J.
if you plan on driving it and really want it to hold up...
first thing is to get it super clean..
then epoxy primer
then a high solids polyurethane paint.
this is the paint i used. also used u-tech epoxy primer
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Engine painting, what do you do? [Re: abodyjoe] #945382
03/11/11 02:59 PM
03/11/11 02:59 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I just use the Plast-kote in a can with several coats & then clear coat. Looks good after several years.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
