Flare up on 1-2 shift #945312
03/07/11 03:42 PM
03/07/11 03:42 PM
Rancho Cucamonga,Ca
3
392charger Offline OP
Rancho Cucamonga,Ca
Okay, getting all the bugs worked out on a fresh 440/727 we just installed in a 69 GTX (thanks for everyones help. This thing burns some serious rubber ). What causes the flare up at the 1-2 shift? Band adjustment? 2nd to 3rd shift is nice and solid. Oh, and the kick down isn't working either. Has a Lokar cable on it. Thanks!
Re: Flare up on 1-2 shift [Re: 392charger] #945313
03/07/11 03:45 PM
03/07/11 03:45 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I get the same reaction with a 80,000 unrebuilt 727 in my Truck with a 440/727. I just figured that the trans is fragged.
Re: Flare up on 1-2 shift [Re: 392charger] #945314
03/07/11 06:41 PM
03/07/11 06:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Gee. That's unusual....not.
Re: Flare up on 1-2 shift [Re: John_Kunkel] #945315
03/07/11 06:56 PM
03/07/11 06:56 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Re: Flare up on 1-2 shift [Re: 392charger] #945316
03/07/11 06:59 PM
03/07/11 06:59 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Quite often that is the kickdown band set to loose!
Re: Flare up on 1-2 shift [Re: Dodgem] #945317
03/07/11 07:59 PM
03/07/11 07:59 PM
Rancho Cucamonga,Ca
3
Rancho Cucamonga,Ca
Is the kick down band adjuster the one on the outside of the trans?
Re: Flare up on 1-2 shift [Re: 392charger] #945318
03/07/11 08:28 PM
03/07/11 08:28 PM
U.S.S.A.
U.S.S.A.
yes.
Re: Flare up on 1-2 shift [Re: 392charger] #945319
03/07/11 09:10 PM
03/07/11 09:10 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
IF this has been flaring-UP for some time ... you might have hurt the band OR evn the drum also .....
DROP the pan and check the pull on the front apply lever.
Re: Flare up on 1-2 shift [Re: 392charger] #945320
03/08/11 06:35 AM
03/08/11 06:35 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
First, it isn't a kick down , it is a throttle pressure valve.
It tells the trans what power it is going to get!!
You are over powering it and slipping the front band. There should be no flair up on the 1-2 shift. If the band is adjusted wrong it can flair on the 2-3 shift.
Re: Flare up on 1-2 shift [Re: JohnRR] #945321
03/08/11 10:10 AM
03/08/11 10:10 AM
scratchnfotraction Offline
Re: Flare up on 1-2 shift [Re: fox] #945322
03/08/11 11:07 AM
03/08/11 11:07 AM
U.S.S.A.
U.S.S.A.
Exactly , 1-2 shift is just the band applying and stopping the drum , till the drum stops you are in FIRST gear, if you are seeing the rpm jump then the rear clutch is slipping, which is not a good thing either.
