Re: Any aftermarket/small power steering pumps
[Re: Montclaire]
#945297
03/07/11 05:07 PM
03/07/11 05:07 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
I purchased a very small p/s pump some time ago (we're making brackets at the moment). I'll see if I can dig out a photo & get manufacturer details. Has remote reservoir.
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: 71TA]
#945298
03/07/11 05:16 PM
03/07/11 05:16 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
The circle track guys have tons of kits. Seach Speedway Motor or other circle track parts houses. They offer a aluminum housing pump too. Problem is there are no Mopar brackets. But Rocketride said he modified a Chevy SB bracket. PM Rocketride. Here is one of those circle track units on the Hotchkis E-Max Challenger.
[Re: Jerry]
#945301
03/07/11 06:23 PM
03/07/11 06:23 PM
autoxcuda
So Cal
i use one from a jeep for my serpentine belt conversion.
I have not seen a Small or Big Block Mopar adjuster bracket kit for all these new mini type power steering pump. They sell them in kits for the hot rod guys now. The pump is common for all these kits. Just no one makes Mopar adapters.
They are made of a flat plate and then round tube standoff from the block.
Jerry, could this be a product opportunity??
[Re: Jerry]
#945303
03/11/11 01:15 PM
03/11/11 01:15 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
Jerry, I would be interested in a bracket that mounts the GM Type II pump to a small block for a Rack and Pinion conversion that uses a GM rack. I would be using a V pulley. Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: autoxcuda]
#945305
03/11/11 02:26 PM
03/11/11 02:26 PM
Posts: 1,024 In the twisties
RokketRide
super gas
super gas
In the twisties
KRC has one for SB Mopar, Hotchkis and I are using the same bracket. The problem is that the 3rd pickup point does not exist on all blocks, seems pretty common to newer engines (Magnums).
Bolt hole in question is just right and above freeze plug:
KRC SB Mopar bracket:
Hotchkis made an extension tab and ran a long bolt from the engine mount. I made a Z bracket. Similar solution to same problem.
[Re: RokketRide]
#945306
03/11/11 02:40 PM
03/11/11 02:40 PM
finadk
East Brunswick, NJ
Thanks!! I also found a setup at www.hotrodlane.cc shown in the link below but I cant find a decent picture of how it fits to the block. http://www.hotrodlane.cc/08%20catalog/Page%20149.pdfI will look tonight to see if I have the hole in the block. If anyone has pictures of the pump installed it would really help me out. Thanks Scott
Scott
1976 Corvette
