71 383 dual snorkel air cleaner resto ??? #945265
03/07/11 01:28 PM
03/07/11 01:28 PM
Wisconsin
FFwithRT Offline OP
FFwithRT  Offline OP
Wisconsin
I am trying to get my stuff together on my 71 RR restoration and wondered if anyone had ever tried restoring an air cleaner on a 71 383 dual snorkel? I want the "spackle " type finish on mine, and I would also be interested in knowing if there is anyone who offers that service? Thanks, Greg ffgreg32@aol.com (Showing picture of what I want it to look like)
Re: 71 383 dual snorkel air cleaner resto ??? [Re: FFwithRT] #945266
03/07/11 02:06 PM
03/07/11 02:06 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
When you say "spakle" what you mean is "wrinkle finish". Over the counter at any auto parts store. Best bet is buy a cheap sand blaster and blast and paint it yourself.
Not a krinkle finish but you get the idea.
Before;
I have mechanical Aptitude.
I can screw up anything.
Re: 71 383 dual snorkel air cleaner resto ??? [Re: bboogieart] #945267
03/07/11 02:07 PM
03/07/11 02:07 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
In porcess
Re: 71 383 dual snorkel air cleaner resto ??? [Re: bboogieart] #945268
03/07/11 02:07 PM
03/07/11 02:07 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Done.
Sorry for the poor lighting.
you should get the idea.
Less than $50.00 including the blaster, blasting media, and paint.
If you don't have a compresser you can do a good job with a wire wheel in a grinder or even a drill. Just takes longer.
Re: 71 383 dual snorkel air cleaner resto ??? [Re: FFwithRT] #945269
03/07/11 02:39 PM
03/07/11 02:39 PM
MassHole Central
rtman Offline
rtman  Offline
MassHole Central
Is there a Harley dealership near you? They have a wrinkle finish spray paint in a rattle can. Looks good when baked after spraying.
Re: 71 383 dual snorkel air cleaner resto ??? [Re: rtman] #945270
03/07/11 02:46 PM
03/07/11 02:46 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've done dozens of air cleaners & Hemi valve covers.. There are plenty of wrinkle finish spray paints out there that work pretty well, the tricks are heavy coats, time in between coats & a good even heat source that can bring the entire part up to about 130- 150 degrees... But since having a part powder coated with wrinkle finish & seeing how smooth and consistent the texture was I doubt I'll do many more wrinkle finish parts with a spray can unless I'm trying for a true OE finish where runs & sags are not only acceptable they are so much the norm that they are expected...
Re: 71 383 dual snorkel air cleaner resto ??? [Re: 1_WILD_RT] #945271
03/07/11 03:37 PM
03/07/11 03:37 PM
State of Fascism
52savoy Online content
52savoy  Online Content
State of Fascism
A heat gun or hair dryer will work too. I also put mine in the bright sunlight. It saves on electric.
Re: 71 383 dual snorkel air cleaner resto ??? [Re: 52savoy] #945272
03/07/11 10:40 PM
03/07/11 10:40 PM
IL
71383beep Offline
71383beep  Offline
IL
I had mine powder coated with the wrinkle finish. I believe the guy used a harley product IIRC.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: 71 383 dual snorkel air cleaner resto ??? [Re: 71383beep] #945273
03/08/11 11:28 AM
03/08/11 11:28 AM
Wisconsin
FFwithRT Offline OP
FFwithRT  Offline OP
Wisconsin
Looks great, I think I will check out the local powder coater, and see if they can do it. Thanks all!
Re: 71 383 dual snorkel air cleaner resto ??? [Re: FFwithRT] #945274
03/08/11 03:09 PM
03/08/11 03:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I can get it real consistant.
Just heat the part in the oven to 300 degrees. Put down a cover coat. Back in the oven. Repeat with thin coats 3-4 times. Will build up a little more wrinkle with coats. Leave in oven for about 2 hours. Smells like heck. But real nice.
Not as rough as wrinkle as the ones I've got powdercoated.
MUCH more durable that outside air drying. I can take my finger nail with pressure across the paint with no paint damage.
Re: 71 383 dual snorkel air cleaner resto ??? [Re: autoxcuda] #945275
03/08/11 06:54 PM
03/08/11 06:54 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'm pretty sure 3M Body Shultz will give you same result
