Re: A518 swap ?'s 69 Dart GT
[Re: skep419]
#945233
03/07/11 01:11 PM
03/07/11 01:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Looking to swap a A518 into the Dart.
It has a 360 ede heads, comp xe284, 8 3/4 3.91 742 suregrip,245/60R15. Would like to Drive to the track 110 miles away 2-5 times a year.
What is different internally between the Lock up 3 pin and the Non lock up 2 pin. ( I would like to build a Non lock up. I have a spare 727 wondering if it would just be a matter of swapping input shafts.) The lock up style 3 pin are a lot easier to find. Also wondering how much heat am I going to have to deal with by running a 3000-3500 converter. (right now I have a midwest 3000, eventually going to buy a turbo action 3500)
I read that there is a full manual valve body available that allows you to shift into 4th? I sent keith at 727specialist a email Friday. Waiting to hear back.
I have both front floor pans cut out. Want to get all the info I can before I buy a trany.
Thanks Sam
I am putting a 518 in my Rampage drag week car and am using the 3 pin type... I didnt want the lock up so I could use one of my race converters so I got the input shaft from CRT.. I ended up getting the whole pump instead of the support due to the mid shaft size... the newer 518s have a smaller end on the mid shaft so the standard 727 input wont work. If you can find a 2 pin thats the way to go... I also went with the standard style valve body but put the up grade/shift kit so it'll help that
[Re: MR_P_BODY]
#945234
03/07/11 01:18 PM
03/07/11 01:18 PM
Posts: 782 Minnesota
skep419
Minnesota
Thanks Sam
Thanks for the info.
How much was the shaft from CRT if you dont mind me asking?
[Re: skep419]
#945237
03/07/11 01:37 PM
03/07/11 01:37 PM
MR_P_BODY
Excellent info.
What are you planning to run for a cooler? [/quote
Big... not sure yet... I might even go with a A/C condenser with a fan.... space is the issue but I might put it in the rear
