moroso vacuum pump drive #945217
03/07/11 11:10 AM
03/07/11 11:10 AM
new brunswick , canada
bigblocka Offline OP
just wondering if the mandrel that goes into the mounting hub is supposed to be a real tight fit? mine is so tight i will have to beat it in with a hammer which is not what i want to do if i dont have to. any one else run into this?
Re: moroso vacuum pump drive [Re: bigblocka] #945218
03/07/11 11:17 AM
03/07/11 11:17 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Not sure what balancer you have. I have an ati and I am looking at using this.
http://www.jegs.com/i/Aerospace-Components/026/AC-MS-BBCHR/10002/-1
Re: moroso vacuum pump drive [Re: Twin Turbo Mower] #945219
03/07/11 11:47 AM
03/07/11 11:47 AM
i am running a tci rattler with moroso crank trigger. the hub mounts flat against the crank trigger wheel but the front is recessed for the mandrel to go into but like i said it is very tight. any one else?
Re: moroso vacuum pump drive [Re: bigblocka] #945220
03/07/11 11:59 AM
03/07/11 11:59 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
no not that tight u should not need to beat with a hammer i also have a ati
