Re: 727 3rd gear question [Re: GKMOPAR] #945092
03/14/11 12:03 AM
03/14/11 12:03 AM
N
NITROUSN Offline
NITROUSN  Offline
N
When I checked the metal rings in the pump reaction shaft they were very rough. It looks like there is an issue here as they look like they are abnormally worn.
30 plus years ago I had a 70 340 dart with a 727. I did a quick clutch reseal and left the sealing rings go. Bit me. Had a 2-3 shift and slip issue. A lot of times the rings wear due to excess bushing wear. The torky 340 pounds the tranny pretty good. I recommend bushings on almost all rebuilds.
Re: 727 3rd gear question [Re: NITROUSN] #945093
03/14/11 03:45 AM
03/14/11 03:45 AM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
x 55 on reducing input shaft end-play as much as possible. And bushing issues are also a consideration toooo. If the drum is sloppy on the reaction shaft it can even BREAK the rings.
CHECK the drum surface now .. it could be damaged.
