Mini starter info needed, steering shaft is in the way
#944866
03/06/11 10:08 PM
03/06/11 10:08 PM
Posts: 1,198 Duncan, BC... or Lakehead, Ca.
440Dave
My Henry J drag car has hit a snag, the steering shaft collides with the solenoid sticking out of the side of the stock starter. I've looked at several mini starters, and even though they're way smaller, the solenoid is in the same place and will have the same problem. Does anyone make or adapt a starter where the solenoid is on the top or bottom?
Re: Mini starter info needed, steering shaft is in the way
[Re: 440Dave]
#944870
03/06/11 10:53 PM
03/06/11 10:53 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Here are some pictures to show you the adjust ability. And he is a sponsor so I guess you don't have to worry about circumventing the the advertising dollars spent on this forum. https://board.moparts.org/ubbthreads/show...amp;Search=true
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
