Re: Mini starter info needed, steering shaft is in the way
[Re: 440Dave]
#944870
03/06/11 10:53 PM
03/06/11 10:53 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Here are some pictures to show you the adjust ability. And he is a sponsor so I guess you don't have to worry about circumventing the the advertising dollars spent on this forum. https://board.moparts.org/ubbthreads/show...amp;Search=true
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
