stage vi valve pocket relief
#944646
03/06/11 07:52 PM
03/06/11 07:52 PM
Posts: 553 Kentucky
clovis
Kentucky
For those with some experience with the stage vi heads, where to you make the relief in the pocket? Per the picture 1 or 2, or 1 and 2?
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: stage vi valve pocket relief
[Re: tboomer]
#944650
03/06/11 09:29 PM
03/06/11 09:29 PM
Posts: 553 Kentucky
clovis
Kentucky
When I have read about others making the modification, I always envisioned a notch just to keep oil from building up.
Any others?
[Re: clovis]
#944652
03/06/11 10:34 PM
03/06/11 10:34 PM
Posts: 553 Kentucky
clovis
Kentucky
Just for kicks, I put the intake on the heads (off the engine) and put fluid into the spring pockets to see the route the fluid would take. The fluid will spill over toward the rail out of the valve spring pocket before it gets to the bottom of the guide. as mentioned by hank, the transitition back into the lifter galley is higher than the valve cover rail, thus the oil has to get up on the valve cover before it can make its way back into the galley. It seems also that the bottom of the guide and the transitition back into the galley are the same height. This would seem to suggest that the cuts between the valve spring pockets would not have an impact since the oil will build up on the both sides equally.
[Re: clovis]
#944653
03/06/11 11:39 PM
03/06/11 11:39 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
I run Stage -6 heads and I did`nt do anything to the pockets. However I did make external drainbacks to the back of the block.so when I pull the valve covers the oil in the back corner is gone. Works for me.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#944654
03/06/11 11:47 PM
03/06/11 11:47 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I just put knotches in mine to clear the oil out of the pockets but when you pull the valve covers it runs directly out the back corners onto the valve covers. It sucks!!
67' charger 499 RB
10.57 at 127
[Re: 6bblFLASH]
#944655
03/06/11 11:50 PM
03/06/11 11:50 PM
Posts: 553 Kentucky
clovis
Kentucky
Any pictures of your drain back? I would be interested in a more detailed description of what you did?
[Re: dragram440]
#944658
03/08/11 06:39 PM
03/08/11 06:39 PM
6bblFLASH
N.E. Ohio
Ok ,I`see if I have a picture.
[Re: clovis]
#944661
03/08/11 10:37 PM
03/08/11 10:37 PM
6bblFLASH
N.E. Ohio
No pictures in computer,car is not where i can get a picture,so,,,,,,,,,, What i did is drill and tap an 1/8th pipe thead hole in the extreme back outside corner of each head and did the same to the block in the area above where the oil passages are where an oil sender would threaded. Hole will be "half" into inner surface of head to be low enough to drain below valve cover rail. Using 3/16th brakeline and compression fittings to hook it all up. It works just fine. By the time you turnoff the engine and get a valvecover pulled it is drained.
[Re: clovis]
#944662
03/08/11 11:03 PM
03/08/11 11:03 PM
Posts: 16,928 NC
440Jim
NC
When I ran those heads, I would jack up one side of the car before removing the valve cover.
