stage vi valve pocket relief #944646
03/06/11 07:52 PM
03/06/11 07:52 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
For those with some experience with the stage vi heads, where to you make the relief in the pocket? Per the picture 1 or 2, or 1 and 2?
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: stage vi valve pocket relief [Re: clovis] #944647
03/06/11 08:41 PM
03/06/11 08:41 PM
Maple Ridge, BC, Canada
N
NitroFixx Offline
NitroFixx  Offline
N
On the first set of Stage VI's i modified the outsides of the pockets simular to the ones in this pic
Re: stage vi valve pocket relief [Re: NitroFixx] #944648
03/06/11 08:44 PM
03/06/11 08:44 PM
tboomer Offline
tboomer  Offline
That looks good...Do you get better drainback? Do you also modify the spring cups any?
Re: stage vi valve pocket relief [Re: clovis] #944649
03/06/11 09:00 PM
03/06/11 09:00 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
If you are talking about trying to get the oil out of the spring seats, I took a die grinder and ground out wherever I could to try and route the oil back into the lifter gallery.Unlike stock iron heads or Indy-1 heads where the oil will run back into the lifter area the VI heads are a pain in the azz. Even with all the grinding the raised intake ports are so high lots of oil will still run over the valve cover rails onto your HOT headers if you remove you valve covers because the oil has to go up hill to get into the lifter gallery.
Re: stage vi valve pocket relief [Re: tboomer] #944650
03/06/11 09:29 PM
03/06/11 09:29 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
When I have read about others making the modification, I always envisioned a notch just to keep oil from building up.
Any others?
'75 Plymouth Duster
Re: stage vi valve pocket relief [Re: clovis] #944651
03/06/11 09:52 PM
03/06/11 09:52 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
Yes , that looks good. Thats were I modified mine also. No problems with oil pooling around the seal. I use blue PC viton seals with good luck.....Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: stage vi valve pocket relief [Re: clovis] #944652
03/06/11 10:34 PM
03/06/11 10:34 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Just for kicks, I put the intake on the heads (off the engine) and put fluid into the spring pockets to see the route the fluid would take. The fluid will spill over toward the rail out of the valve spring pocket before it gets to the bottom of the guide. as mentioned by hank, the transitition back into the lifter galley is higher than the valve cover rail, thus the oil has to get up on the valve cover before it can make its way back into the galley. It seems also that the bottom of the guide and the transitition back into the galley are the same height. This would seem to suggest that the cuts between the valve spring pockets would not have an impact since the oil will build up on the both sides equally.
'75 Plymouth Duster
Re: stage vi valve pocket relief [Re: clovis] #944653
03/06/11 11:39 PM
03/06/11 11:39 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I run Stage -6 heads and I did`nt do anything to the pockets.
However I did make external drainbacks to the back of the block.so when I pull the valve covers the oil in the back corner is gone.
Works for me.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: stage vi valve pocket relief [Re: 6bblFLASH] #944654
03/06/11 11:47 PM
03/06/11 11:47 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I just put knotches in mine to clear the oil out of the pockets but when you pull the valve covers it runs directly out the back corners onto the valve covers. It sucks!!
67' charger 499 RB 10.57 at 127
Re: stage vi valve pocket relief [Re: 6bblFLASH] #944655
03/06/11 11:50 PM
03/06/11 11:50 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Any pictures of your drain back? I would be interested in a more detailed description of what you did?
'75 Plymouth Duster
Re: stage vi valve pocket relief [Re: clovis] #944656
03/07/11 12:09 AM
03/07/11 12:09 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Me too.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: stage vi valve pocket relief [Re: BloFish] #944657
03/07/11 12:29 AM
03/07/11 12:29 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Me to!
Re: stage vi valve pocket relief [Re: dragram440] #944658
03/08/11 06:39 PM
03/08/11 06:39 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Ok ,I`see if I have a picture.
Re: stage vi valve pocket relief [Re: clovis] #944659
03/08/11 06:42 PM
03/08/11 06:42 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Mine just have the channel cut between the adjoining pockets so that the seals aren't constantly flooded. But there's always a lot of oil hanging out around the gasket area when I pull the valve covers.
Re: stage vi valve pocket relief [Re: BradH] #944660
03/08/11 07:08 PM
03/08/11 07:08 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
those cast in valve seat cups look plain scary
Re: stage vi valve pocket relief [Re: clovis] #944661
03/08/11 10:37 PM
03/08/11 10:37 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
No pictures in computer,car is not where i can get a picture,so,,,,,,,,,,
What i did is drill and tap an 1/8th pipe thead hole in the extreme back outside corner of each head and did the same to the block in the area above where the oil passages are where an oil sender would threaded. Hole will be "half" into inner surface of head to be low enough to drain below valve cover rail.
Using 3/16th brakeline and compression fittings to hook it all up.
It works just fine.
By the time you turnoff the engine and get a valvecover pulled it is drained.
Re: stage vi valve pocket relief [Re: clovis] #944662
03/08/11 11:03 PM
03/08/11 11:03 PM
NC
440Jim Offline
440Jim  Offline
NC
When I ran those heads, I would jack up one side of the car before removing the valve cover.
