Re: Explain some engine theory to me......
[Re: Yancy Derringer]
#944291
03/06/11 07:16 PM
03/06/11 07:16 PM
DaytonaTurbo
Manitoba, Canada
Well you probably don't want to hear this little complication, but there are what used to be called "flat cranks" which have the throws at 180* I believe Ferrari does or did use these. At one time, a certain amount of drag racers used to experiment with 'em.
That would be basically the same as an inline engine crank. I always figured the reason the v8 cranks were offset like that was for engine smoothness or something to do with the way the crank gets worked under load...
[Re: DaytonaTurbo]
#944293
03/06/11 08:39 PM
03/06/11 08:39 PM
Posts: 606 Montana
Yancy Derringer
Montana
Depends on the "inline" 6 cylinder engines are not 180, they are every third of a turn, IE every 120
4 whanger would be 180
