Re: Federal Power Steering Pump Rebuild Kit Source?
[Re: mkvien]
#944275
03/06/11 06:49 PM
03/06/11 06:49 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
Give these a try, I got one for a Saginaw pump for $14. http://pskits.com/
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: mkvien]
#944277
03/06/11 07:09 PM
03/06/11 07:09 PM
I rebuilt my Saginaw a few years back with a kit from Autozone. $11.00 at the time...
[Re: mikemee1331]
#944278
03/06/11 07:26 PM
03/06/11 07:26 PM
Posts: 70 MN
mkvien
MN
i looked on rockauto the other day and they had them?? most large auto parts stores can also get them.
Maybe I wasn't looking under the right thing, do you have a part number? Problem is that I am not sure what application the pump I have would have originally been used for. I live quite a long way from a "large" auto part store. What model would a guy ask for if I were to get one? If I say a Federal Mopar pump they will just look at me all cross-eyed.
[Re: Mick70RR]
#944279
03/06/11 07:31 PM
03/06/11 07:31 PM
Posts: 70 MN
mkvien
MN
http://pskits.com/
Is the one I am looking for the 5th one down in the Dodge section? It says "Pump Kits / 400-1000 Series / 63-73" for $14.09.
[Re: mikemee1331]
#944281
03/06/11 10:59 PM
03/06/11 10:59 PM
Posts: 70 MN
mkvien
MN
206114 - remanufactured by A-1 Cardone or NAPA - http://www.napaonline.com/Search/Results...8+50020+2020012
It looks like a rebuild service, anyone ever done that with Rockauto? Or do they just recommend you send one in and if you don't they stick you for $45 core charge?
[Re: mikemee1331]
#944283
03/08/11 12:19 AM
03/08/11 12:19 AM
Posts: 70 MN
mkvien
MN
no dude, that's not how it works. you buy a rebuilt unit from them. they charge you a 'core charge' on top of the cost or the new unit. when you send them the old busted unit, they refund the 'core charge'.
That's what I would have thought too, but it says return and rebuild service only, and there is a 3-5 day time for the rebuild.
[Re: Sixpak]
#944287
03/09/11 12:58 AM
03/09/11 12:58 AM
Posts: 70 MN
mkvien
MN
Rock Auto has the seal or a complete rebuild kit.
GATES Part # 348710 Power Steering Repair Kit W/Chrysler P.S. Pump
GATES Part # 351170 More Information About this Part Power Steering Repair Kit W/Chrysler P.S. Pump
BE SURE you have the correct pulley puller. You cannot replace the seal without it. It is not keyed on and held on with a nut like the Saginaw pump, it is pressed on. The puller wraps around that big flange and then presses the pulley off the shaft. If you do decide to get a new pump you MUST remove your old pulley before using your old pump as a core - you will NOT get the pulley with a rebuilt pump!
Be SURE you mean the Federal pump, NOT the TRW pump. They look nearly identical but I have never rebuilt a TRW pump, so I can't say if they are the same. TRW pumps came on some 68 and back big block motors. A TRW pump pulley presses on also.
Thanks for the info. I do have the correct puller and the pulley off already. It is the Federal pump for sure, I found pictures comparing the 2 and you can tell the difference pretty clearly by the design on the back.
I appreciate the info, just what I was looking for. Thank you.
