340 stroker #944268
03/06/11 06:15 PM
03/06/11 06:15 PM
Virginia
hokies1 Offline OP
hokies1  Offline OP
Virginia
I want to stroke my 340 to 416. I plan on using a scat stroker kit and RHS heads. The car it will go in is a 71 duster with auto and 3:91 gears. I want to use a roller in this build, any suggestions thanks.
Re: 340 stroker [Re: hokies1] #944269
03/06/11 07:54 PM
03/06/11 07:54 PM
SoCal
Brian Hafliger Offline
SoCal
I'm guessing hyd. roller? I generally use a cam that has 242-248 @ .050 and around .580 lift.
I'd have to know the whole combo, engine, car, etc...to spec the cam.
Brian Hafliger
IMM Engines
Brian Hafliger
