383 oil pump removal #944086
03/06/11 02:14 PM
03/06/11 02:14 PM
Rhode Island
browndevil Offline OP
Rhode Island
My seals on my oil pump are leaking on my 1970 383 so I am trying to remove the pump to replace the seals and gasket. The engine is in the car. I removed the bolts per my service manual. I can rotate the pump but I cannot get it to come off. Is there some trick to remove it?
Thanks,
Michael
Re: 383 oil pump removal [Re: browndevil] #944087
03/06/11 02:20 PM
03/06/11 02:20 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You might need to pull the distributor and the intermediate shaft.
Re: 383 oil pump removal [Re: browndevil] #944088
03/06/11 02:22 PM
03/06/11 02:22 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It'll come out with some creative, but light prying.
Re: 383 oil pump removal [Re: browndevil] #944089
03/06/11 02:24 PM
03/06/11 02:24 PM
okla.
sam64 Offline
sam64  Offline
okla.
insert a thin flat blade screw driver between block and pump,you may have to tap it in to get it started ,shouldn't take a whole lot of pressure to un seat the oring thats probably holding it.
Re: 383 oil pump removal [Re: sam64] #944090
03/06/11 02:33 PM
03/06/11 02:33 PM
Rhode Island
Rhode Island
Thanks guys. I wedged a small tapered platic wedge under the pump, rotated the pump onto it a little, and it popped right off. Thanks for
all your help.
Michael
