I never seen before #944081
03/06/11 01:49 PM
03/06/11 01:49 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
2001 jeep Grand Cherokee radiator tank blow out from the top hose inlet down what would cause this?? beside being old??
Re: I never seen before [Re: BigTerry] #944082
03/06/11 04:25 PM
03/06/11 04:25 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Years of use can weaken the radiator, sure. The one thing that can blow out a radiator quickly is a blown head gasket! The sudden introduction of compression pressure into the cooling system can overwhelm the aged radiator seams and cause a blowout as you have experienced. I sure hope its just a worn out radiator though. Good luck.
Re: I never seen before [Re: Kern Dog] #944083
03/06/11 06:58 PM
03/06/11 06:58 PM
pa.
dan9 Offline
dan9  Offline
pa.
My 1997 Jeep did the same thing just as i had parked at a drive-in embarrasing as it was it seems that plastic tank was weak. A new one was only $88 and they had it in stock .
Re: I never seen before [Re: BigTerry] #944084
03/06/11 08:36 PM
03/06/11 08:36 PM
rhode island
bomber1965 Offline
bomber1965  Offline
rhode island
is it the straight six?
Engines installed in 1999 Grand Cherokees carried the PowerTech name, which had been used intermittently in prior years and on other Chrysler truck and SUV engines. The name was subsequently passed on to 4.0s in the other Jeep models that used the engine, the Cherokee and Wrangler. The cylinder head was again changed for the 2000 model year to a lower flowing, more emissions-friendly design. This head was designated as "0331" in the casting number. These heads are prone to cracking and causing coolant to contaminate the oil, resulting in catastrophic engine failure.
amc six
Re: I never seen before [Re: bomber1965] #944085
03/06/11 10:15 PM
03/06/11 10:15 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
4.7 I forgot to include that sorry!
