Mini tub - any mods needed to fit the stock rear seat ? #944075
03/06/11 01:32 PM
03/06/11 01:32 PM
Winnipeg, Canada
StrokerDart Offline OP
Winnipeg, Canada
I'm pondering doing the mini tub job to my 76 Dart Sport .... can anyone tell me if the stock rear seat can easily be retained ?
Will a lot of modification to the seat be required ... or, hopefully none ??
thanks for any help !
Re: Mini tub - any mods needed to fit the stock rear seat ? [Re: StrokerDart] #944076
03/06/11 02:01 PM
03/06/11 02:01 PM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
I have done a couple and the only mod I have had to make was the slight rearrangement of one seat spring on each side for clearance. Other than that, no issue. Just heat it with a torch and re bend to suit.You may or may not have to do that.And this only applies if you are re-using the stock wheelhouse.If using an A/M wheeltub I think you are S.O.L.- no back seat unless a full custom seat?
Re: Mini tub - any mods needed to fit the stock rear seat ? [Re: BEEQUIK] #944077
03/06/11 02:10 PM
03/06/11 02:10 PM
Winnipeg, Canada
Winnipeg, Canada
thanks !
yes, it will be re-use of the stock inner wheel house ... so this is sounding promising so far
Re: Mini tub - any mods needed to fit the stock rear seat ? [Re: StrokerDart] #944078
03/06/11 02:40 PM
03/06/11 02:40 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We used aftermarket tubs in our 71 Demon and as BeeQuik mentioned,if you use those..no back seat unless custom made.
Nautilus Racing-
Re: Mini tub - any mods needed to fit the stock rear seat ? [Re: Chris2581] #944079
03/06/11 04:49 PM
03/06/11 04:49 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
E bodies are not that easy though....because of the plastic rear panels.
I planned on mini tubbing my street cuda, but decided against it because it wuld mess up the fit of the rear interior panels.
Re: Mini tub - any mods needed to fit the stock rear seat ? [Re: StrokerDart] #944080
03/06/11 08:17 PM
03/06/11 08:17 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
My Valiant is mini tubbed and I just cut the piece BeeQuick bent, lol. Not exactly a show car here and no one sits back there anyway.
