Stock Big Block Oil pan numbers, what application? #943997
03/06/11 12:31 PM
03/06/11 12:31 PM
S.E. Conn
Hoof Hearted Offline OP
S.E. Conn
I have 2 BB oil pans that i've had for years and don't know if they are 383, 440, 413? B-Body, C-body?
Raised numbers on bottom read: 187 & ___699 .
Thanks for your input!
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Stock Big Block Oil pan numbers, what application? [Re: Hoof Hearted] #943998
03/06/11 12:37 PM
03/06/11 12:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
187 is 67-70 C barge , the 699 is 72-73 C barge , engine size does not matter as long as it's a BIG BLOCK , do either have internal baffles ?
Re: Stock Big Block Oil pan numbers, what application? [Re: Hoof Hearted] #943999
03/06/11 12:48 PM
03/06/11 12:48 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Both of those pans are the desired pans to put a big block in an A body. They have they clearance for the steering arm.
Re: Stock Big Block Oil pan numbers, what application? [Re: R/T1968R/T] #944000
03/06/11 01:19 PM
03/06/11 01:19 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i,m seeking a 187 pan with baffles if yours has them dan
