Rear Axles #943931
03/06/11 08:46 AM
03/06/11 08:46 AM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
Pulled the axles out of a 8 3/4 rear today and was surprized to see there are no axle seals in the rearend housing but the axle bearing has an o ring seal around the bearing. The axles aren't Mopar axles because they don't have the hole in them to get at the retainer nuts and the end of the axle is flat where the brake drum slides over.It is also stamped M E on the end. What for axles are these things?
Re: Rear Axles [Re: 72 RR DUDE] #943932
03/06/11 09:33 AM
03/06/11 09:33 AM
BDW Offline
BDW  Offline
Re: Rear Axles [Re: 72 RR DUDE] #943933
03/06/11 10:55 AM
03/06/11 10:55 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Sound like Mosers.
Re: Rear Axles [Re: buildanother] #943934
03/06/11 12:11 PM
03/06/11 12:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sound like Mosers.
With Green bearings
