Part # request, Voltage regulator 1966 B-body #94380
07/25/08 01:24 PM
07/25/08 01:24 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Title says it all, Any one have a part number for a true electronic regulator for a 1966 coronet . I picked up a Standard VR101 and it has points in it
Thanks in advance
Re: Part # request, Voltage regulator 1966 B-body [Re: gtx6970] #94381
07/25/08 01:29 PM
07/25/08 01:29 PM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
I've bought from here. Works good so far.
http://www.holcombedirect.com/browse.cfm/4,894.htm
Re: Part # request, Voltage regulator 1966 B-body [Re: 65Frank] #94382
07/25/08 09:32 PM
07/25/08 09:32 PM
Denver,NC
hemiheadNC Offline
hemiheadNC  Offline
Denver,NC
...use the WELLS VR706 from Auto Zone and others ,only about 5/8 to 3/4 inch tall and no volt fluctuation or jumping around like a point system. If you remove the cover, a stock Mopar tall cover will fit and makes it all look stock !!
