aftermarket fuel gauge. #943308
03/05/11 09:23 AM
03/05/11 09:23 AM
maryland
jackassjeeper97 Offline OP
maryland
I am looking into running a aftermarket fuel gauge in my 67 gtx until I have the cluster restored(nothing works) Has anybody done this and if so could you steer me in the right direction? Thanks
Re: aftermarket fuel gauge. [Re: jackassjeeper97] #943309
03/05/11 10:40 AM
03/05/11 10:40 AM
IN
ahy Offline
ahy  Offline
IN
Autometer has a line of 12V fuel guages setup to the MOPAR resistance levels. Specs are roughly 10 ohms full and 78 ohms empty. If you run a umper from the tank to fuel guage wire to the aftermarket guage and hook up switched 12 volts to the guage you've got it. If you use the search feature at Summit you can get a list of compatible guages.
Re: aftermarket fuel gauge. [Re: ahy] #943310
03/05/11 06:42 PM
03/05/11 06:42 PM
maryland
maryland
Thank you
Re: aftermarket fuel gauge. [Re: jackassjeeper97] #943311
03/05/11 06:49 PM
03/05/11 06:49 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
You can also call Autometer, or any of the big guage Co.s and they'll be able to set you up with the correct ohm for Mopar. I did a complete guage change in this dart and hooked into the rear harness to the sending unit.
