moroso says..........about vacuum pump? #943011
03/04/11 10:47 PM
03/04/11 10:47 PM
glendora, ca.
Deepockets Offline OP
glendora, ca.
moroso says that there pump must be mounted on the passenger side, but does'nt explain why. i hav'nt called them, does anyone here know why you should'nt. it will still rotate the same direction.
Re: moroso says..........about vacuum pump? [Re: Deepockets] #943012
03/04/11 10:58 PM
03/04/11 10:58 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Mine is on drivers side, works great ..
Had to putz with it to get it working at the suction point to stop the major draw of oil
Don't expect a whole lotta tech from them
been there, done that
Re: moroso says..........about vacuum pump? [Re: bigdad] #943013
03/04/11 11:03 PM
03/04/11 11:03 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I could not suck from the front of the V/C worked ok on dyno but not on the track
Filled the res on a pass, moved it to center/top of V/C now it draws about a OZ' a pass
Re: moroso says..........about vacuum pump? [Re: bigdad] #943014
03/04/11 11:05 PM
03/04/11 11:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine is also n the drivers side. Dont see why it matters the directions are pretty clear on the plumbing to make sure it is correct, dont see why the side would matter as long as it is plumbed correctly.
Re: moroso says..........about vacuum pump? [Re: Al_Alguire] #943015
03/04/11 11:07 PM
03/04/11 11:07 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Bottom line and I hope Al agrees, you have to fool with it to get it to work on YOUR application
Re: moroso says..........about vacuum pump? [Re: bigdad] #943016
03/04/11 11:11 PM
03/04/11 11:11 PM
glendora, ca.
glendora, ca.
well that good to hear. i mounted it on the drivers side since the pass side is bussy like big dads. i cant in all my life figure out why they say that. i'm at ease now. thanks
Re: moroso says..........about vacuum pump? [Re: Deepockets] #943017
03/04/11 11:17 PM
03/04/11 11:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine has been there for 230+ passes and is still working great. Very busy from the block to the radiator on mine. If you look under the oil filter you will find mine hiding there.
Re: moroso says..........about vacuum pump? [Re: Deepockets] #943018
03/04/11 11:19 PM
03/04/11 11:19 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The Moroso tech is one of the poorest there is IMO
I think I know more than they do at this point and thats not saying much !
I got some tips here and from some others and just kept fooling with it till it worked right
My BIGGEST TIP ..
Get a QUALITY gauge to know what is really doing ,just cause it looks like it is working does not mean it is
I watch my gauge as close as the oil, water,etc
Re: moroso says..........about vacuum pump? [Re: bigdad] #943019
03/04/11 11:42 PM
03/04/11 11:42 PM
Lehigh Acres, Florida
rickstershemi Offline
Mine was on the d/s.....that just doesn't make sense
Rickster
Re: moroso says..........about vacuum pump? [Re: rickstershemi] #943020
03/05/11 11:07 AM
03/05/11 11:07 AM
New Braunfels, TX
BigBlockScamp Offline
New Braunfels, TX
My guess is that it originated for turning left in circle track racing.
