69 Coronet R/T - Factory undercoating question #942903
03/04/11 09:19 PM
03/04/11 09:19 PM
Williamsport, PA
Rob440Magnum Offline OP
mopar addict
mopar addict
Williamsport, PA
Did all cars come with factory undercoating or was that a dealer installed option? I'm not talking about the wheel wells, I'm more interested in the underneath. Is it coded on the buildsheet somewhere?
If you know could you please elaborate on the details of where and how it was done?
Thanks, Rob
Re: 69 Coronet R/T - Factory undercoating question [Re: Rob440Magnum] #942904
03/04/11 10:08 PM
03/04/11 10:08 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
It was a factory option code J55 on buildsheet. The factory did it after most components were installed like brake/fuel lines and fuel tank, etc. My Challenger vert was undercoated only on the drivers side, someone was asleep on the job back in Sept 1969...I know the trend is to primer restore without undercoating but most original cars I have seen did indeed have undercoating although my Duster is bare.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: 69 Coronet R/T - Factory undercoating question [Re: Rob440Magnum] #942905
03/05/11 02:16 AM
03/05/11 02:16 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Yes. Look in the J section. If there is a '5' in the J55 box, the car came with undercoating and a hood pad.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 69 Coronet R/T - Factory undercoating question [Re: 69CoronetRT] #942906
03/05/11 02:59 PM
03/05/11 02:59 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
And, if equipped with a fresh air hood option, just the undercoating
Re: 69 Coronet R/T - Factory undercoating question [Re: 70440+6bbl] #942907
03/05/11 03:57 PM
03/05/11 03:57 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Good point
Seeking:
Re: 69 Coronet R/T - Factory undercoating question [Re: 70440+6bbl] #942908
03/05/11 06:12 PM
03/05/11 06:12 PM
Georgia
Matt M Offline
Matt M  Offline
Georgia
I have an A12 Road Runner that is factory undercoated.
It has a 5 on the build sheet.
Re: 69 Coronet R/T - Factory undercoating question [Re: Matt M] #942909
03/06/11 04:45 PM
03/06/11 04:45 PM
Williamsport, PA
mopar addict
mopar addict
Williamsport, PA
would the J55 be on the fender tag also?
