Slant six's question
#942595
03/04/11 04:09 PM
03/04/11 04:09 PM
Posts: 3,054 USA
b54406barrel
USA
I don't think I've ever laid a wrench on a slant 6 so know nothing about them. There's more than one size, apparently? How do you tell the sizes? damper difference, distributor location, etc.? Where would the 'numbers' be on one? Thanks!
If it helps, this motor is in '63 Dodge 330 w/a 3spd stick. Thanks!
Re: Slant six's question
[Re: b54406barrel]
#942596
03/04/11 04:49 PM
03/04/11 04:49 PM
RapidRobert
There's a thin rail w stamped #'s behind the alt & will have 22 for 225 or 17 for 170. Prob need to clean it to see them. www.slantsix.org for more info on /6's. I think the 198 didn't come out till '69 or '70
[Re: b54406barrel]
#942598
03/04/11 07:25 PM
03/04/11 07:25 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
the engines are basically the same other than the 170 and 190 have a shorter hose from water pump to head. its very easy to discern the diff of 225 from the other two by standing by battery and looking across at the water pump hose that runs up to the head . on the 225 the little hose is about 4 inches long where as the 170 190 the hose is about 2 " long
[Re: b54406barrel]
#942602
03/05/11 12:48 PM
03/05/11 12:48 PM
Posts: 3,472 Lubbock, TX
Erics5th
UsedtobeSatellite6
UsedtobeSatellite6
Lubbock, TX
Safe bet you have a 225 in your 330. Only the 170 from that era was used in the A bodys (and later the 198). Though some trucks did use the 170...I believe only fleet use.
Eric
