What solder is best for factory wiring harness?
#942445
03/04/11 09:23 AM
03/04/11 09:23 AM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
I am currently repairing some old splices in my factory harness, and the solder that I have I cannot get to work very well. Is there something i can get at my local Radio Shack?
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: What solder is best for factory wiring harness?
[Re: 11secaarcuda]
#942448
03/04/11 06:17 PM
03/04/11 06:17 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Rosin core solder is for electrical stuff, acid core for radiators etc. You can buy electrical rosin flux and wet the wires before soldering them with rosin core solder. I use a small butane pizo torch for most of my soldering these days. It's so much easier and faster. Once done soldering, wrap electrical tape over the splice then slide your heat shrink tubing over the tape and shrink it. Aluminum foil can be used to protect any heat sensitive items while soldering.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#942449
03/04/11 07:57 PM
03/04/11 07:57 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
I use a small butane "crack pipe" as I like to call it. Works like a charm. Rosin core. Get the thin stuff.
MB
