Re: stock block stroker big block how big do you like them
[Re: earthmover]
#942365
03/04/11 02:59 AM
03/04/11 02:59 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Six years ago I had my current combo ran on a chassis dyno. 1974 440 with the Hensley stroker kit consisting of Eagle 4.15 stroke crank, Ross 10.8 pistons, Box stock Edelbrock 84cc heads, MP '509 cam installed 4 degrees adv, Performer RPM intake, BG 850 vs carb, 1 7/8 headers and 31 degrees of adv in a MP electronic ignition. Any more spark lead and the car detonated like marbles in a coffee can. It recorded a net # of 370 HP and 452 TQ. I expected higher numbers, but the dyno operator said a straight up setting would have helped the cam and move the power range up some. The parasitic drivetrain losses can add between 20-25% for a 727 equipped combo, so I could've been making around 495 HP and 600 TQ at the flywheel.
[Re: RAMM]
#942368
03/04/11 10:31 AM
03/04/11 10:31 AM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
511, 4.25" stroke, limit the build of an RB to ~650-670hp and for a low deck you can safely go to ~720 with a low hard block fill. Girdles help stabilize the Cradle portion of the block and I know guys are making well over 800HP with their stock block race strokers but I won't comment on that which I don't have particular experience building, (but I've "autopsied" a few.)
Cam choice and head flow are critical to an optimized stroker combo, for optimum reliability don't get hung-up on max HP but you can focus on the broadest flattest torque curve you can build while still hitting reasonably high HP targets. You should decide whether you're going with a standard port motor or a max wedge, the ideal "recipie" will be quite a bit different.
Guys that run into bottom end cap walk issues on stock blocks are seeing this because they are effectively trying to turn a moderate RPM torque motor into a peak RPM HP motor; and the comparatively thin walled stock block (intended to a max of maybe 500 lb/ft of torque) will be pushed beyond its limits. And remember the stresses induced by even moderate or momentary detonation WILL push the block well beyond it's capacity. Reliability is further compromised the higher you raise the peak torque RPM. Race blocks have thicker bores and webs and this addresses/counteracts the higher RPM PEAKS this helps high RPM motors considerably because generally (4 cycle engine dynamics 101) once you pass through the peak torque RPM the wall friction of the rings and piston speed primarily starts to act like a brake on the crankshaft, just like a shoe on a drum. The higher the peak torque RPM the more severe these loads will be. I try build the shortblock for overall broad torque and let the heads do the "horsepower work" above the torque peak.
I believe that a 470 3.90 stroke low deck will have the most HP/cube potential in terms of efficiency, but in terms of bang for the buck the 511 is the way to go, ~10% more cubes inthe same package.
[Re: Streetwize]
#942369
03/04/11 10:51 AM
03/04/11 10:51 AM
Posts: 8,937 Holly/MI
Dean_Kuzluzski
Holly/MI
Just wondering what would be the best cylinder head package for the stock/production block??
I'm thinking OOTB Indy EZ's for the money and if an aftermarket block ever mysteriously shows up in garage they can be opened up to accomodate?
[Re: Streetwize]
#942370
03/04/11 10:52 AM
03/04/11 10:52 AM
Posts: 9,990 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have run a 4.15 x 4.375 499, went 9.30s at 3000 lbs with unported 440-1 heads. If I had to do another low deck stock block again it would have the following; 512 cubes. The lightest rotating assembly I could cook up. along with aluminum main caps and a center counter weighted crank. The center weights spread the stress out where it belongs, to all the bearing journals more evenly. Fill the block to start. Find the shortest lightest piston that will fit with an off the shelf aluminum rod. Make darned sure my tuneup is conservative to start. I don't want any possibility of detonation.
[Re: gregsdart]
#942371
03/04/11 11:10 AM
03/04/11 11:10 AM
Posts: 202 Barboursville, VA
belvedere383
Barboursville, VA
I run a 383 based 496, 4.25 stroke, 4.31 bore. It makes in the neighborhood of 710 crank horsepower. It has Indy EZ heads that have been hand ported and a comp .660 [Email]272@.050[/Email] solid roller. Motor makes usaeable power till about 7200 I shift it at about 7000. In a full weight 65 Belvedere with a 4speed it goes 11.0 at about 129 and is still street driven.
The bottom end is a little more beefed up with Pro Gram main caps, and a girdle from chenoworth I beleive.
65' Belvedere
496'' Stroker Indy Heads
[Re: belvedere383]
#942372
03/04/11 11:17 AM
03/04/11 11:17 AM
Posts: 2,449 nc
earthmover
nc
gregsdart please explain this center counter weight crank to me ..i have a idea of what your saying just never really heard of that..mike also the big thing is i have -1 heads unported with 2.25 valve with a nice size cam 280@50 and 731 with the rockers 1.6.. plan to hard block to bottom of water pump holes and cross bolt and girdle
[Re: earthmover]
#942373
03/04/11 11:27 AM
03/04/11 11:27 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
mine is a 69 440-499 block with a eagle crank eagle H beam rods and srp flat top pistons compression is 12.5-1 with stage VI heads hand ported and M1 single plane matched to the heads, doug herbert solid roller 262-265 @ 50 and 620 lift, 1050 dominator 2" hooker super comps. It seems to run real good if I was doing it again I would go with pump gas. The car weighs 3740 with me in it and runs 10.60's with no tuning. As of long jevity not sure as it has low hours on it still. I have the 440 source steel main caps and arp studs.
67' charger 499 RB
10.57 at 127
[Re: earthmover]
#942374
03/04/11 11:48 AM
03/04/11 11:48 AM
Posts: 446 oregon
savoyracer
oregon
Been there, Done that.. .Going through this very same issue right now..mine is a 4.35 bore, 4.375 stroke, 520" stock block 440, 12.4 compression ratio, indy -1 heads from Modern. 3200 lb car runs 9.80 at 138 mph, dynoed at 760hp The block was hard blocked and girdled, aluminum Main Caps. had a thrust bearing issue, pulled it apart, and the block is BROKEN!. where it is broke, the hard block and girdle did not help. I am going to build another one, this time I will NOT waste my money on the hard block and girdle. I talked to Cab Burge about this issue, and you might PM him, and get some good info first hand. As stated above, be very conservative on your tune, Detonation is the big killer, and the other helpful advice I recieved is to lower the compression to around 11 or 11.5 to 1. keep us posted, I am very interested in what you finally decide to do, and how it turned out for you.
[Re: supercomp]
#942376
03/04/11 01:23 PM
03/04/11 01:23 PM
Streetwize
Weddington, N.C.
I don't think it's compression alone but it is the combination of compression and (as stated above) RPM...putting the torque peak too high in the RPM band. where compression kills ANY motor is when you detonate...and the more dynamic compression you have (remember RPM's role here) the less cushion you have...and if you're already well past the design limits...well, you don't need to have a PhD to figure out what happens next....something breaks...and if it don't break it fractures. And I can't tell you how many lucky [Email]b@stards[/Email] found cracked caps or webs on a routine "freshen up" that were time-bombs just waiting to blow. I think you can run high compression and a more conservative cam and RPM cieling and be reliable, I've said it a hundred times that strokers ET on torque so make the most use of it through the middle, don't overcam it (which again put the torque peak too high) = higher than the bores/cradles can cope with on the high RPM power curve. Letting the VE drop off and lowering the peak power reduces the stresses the crank can induce into the block....period. Build the target power (as noted above) as early (fewest RPM that get's there) as you can, ET on torque, don't chase that last MPH...just like the (as any old timer can tell you) the old wedge motor days. Back then we couldn't throw enough head on the blocks to break them, but these days (with several available heads capable of 700+hp) we can....but just because you can, doesn't mean you should 99% of you bracket race, maybe I'm over conservative but if I can go 9.81's turning only 6800 RPM RELIABLY, i can learn to have as much long-lasting fun as going 9.69 turning 7400, I can't tell you how many stroker guys say they short shifted by accident and the car only ET'ed a 10'th slower....again, you're ET'ing on torque! With strokers any time you increase the stroke you are shortening the "ideal" or "natural" RPM band between peak torque and Peak Power, spin it up much higher than that and you're not only adding a lotmore stress, you're also getting diminishing returns relative to the same size engine with a bigger bore shorter stroke combo (that produces less piston speed = wall friction). I will buy a low deck 4.500" bore Iron block as soon as World or Koleno wake up and give us one, but even then I'll limit the stroke to 4.25-4.30.
[Re: Streetwize]
#942378
03/04/11 03:02 PM
03/04/11 03:02 PM
Posts: 43,141 Bend,OR USA
Cab_Burge
99% of you bracket race, maybe I'm over conservative but if I can go 9.81's turning only 6800 RPM RELIABLY, i can learn to have as much long-lasting fun as going 6.69 turning 7400, I can't tell you how many stroker guys say they short shifted by accident and the car only ET'ed a 10'th slower....again, you're ET'ing on torque!
Lower the compression to less than 12.0 on race gas and or run E85 or alcholol My 518 C.I low deck stroker with 10.78 to 1 comp. ratio makes the exact same power(775 HP at 6500 RPM) on Oregon pump gas as my 527 C.I 12.8 to 1 comp. ratio motor does on 110 octane race gas
[Re: Cab_Burge]
#942379
03/04/11 06:40 PM
03/04/11 06:40 PM
dragram440
bigfork mn
So you think turning a stock block stroker to 6500 and under you have alot better chance of survival? Even with 12.5-1 compression? I want mine to live as long as possible.I also have a 3/8 oil pick up so I have been trying not to over rev it. How high is to high?
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#942380
03/04/11 09:08 PM
03/04/11 09:08 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
My new combo only has 9 runs on it. But the tracks open tomarrow . It's a 541ci (4.375 bore X 4.5 stroke) in a 77 440 block. I guess you can say I don't agree with the hype around here . It's just a 345CnC -1 headed, ultradyne .680/.280. Bla bla bla. These experts would hate for me to tell you it's mostly 440source stuff with stock caps lmao it does have GRP rods though
[Re: @#$%&*!]
#942382
03/04/11 11:12 PM
03/04/11 11:12 PM
FastmOp
Hot Rod Ridge
Where's the Time Bomb emoticon?
look under your hood
I built my 500ci 69 440 block stroker in 2002. I pulled it last summer cause it was showing an oil pressure drop and sounded a little off. It was an intake rocker ha ha ha. It ran 6.20's to 6.teens. It's now in my Avenger waiting to be ran again. When you have 400 runs on a motor that makes any kind of steam that YOU built then I might care what you think.
The new combo went in the teens in three passes and went 6.16 it's last pass. That's 112mph in the 1/8. I know it's got more in it as soon as I get these headers I'm building for it done. The hooker fenderwells are holding it back.
The guy wants to know what can be built with a stock block. That's what I told him. You seem to think since you can't do it nobody can. Well that's why I built it like this ha ha ha.
Yes I'll post pics when it goes. Just like I posted a breakdown of it in the other post. It's racing, stuff happens.
You don't even want to know what I have in mind for the 500ci motor
[Re: dragram440]
#942383
03/04/11 11:29 PM
03/04/11 11:29 PM
Cab_Burge
I shift my pump gas 518 C.I. 400 block stroker motor at or slightly above 7000 RPM, the 440 block stroker motor probally at or under 6500 RPM As far as helping make the motor live I think E85 or pure alcholol will help prevent detonation, not just the shift RPMs If your going to use race gas I would shoot for 12.0 to 1 comp. ratio or lower The last 440 block I saw that had cracked the main webs had 14.7 to 1 comp. ratio I have seen B and RB motors break the stock main caps on race gas but not on alcholol or E85, yet I treid buying some of the old Mopar brand ductile iron main cap kits last week, no luck on either the B or RB motor kits, that leaves two options on replacing the stock main caps, steel or aluminum I like steel better than aluminum
