1984 Ram VAN 250 brake proportioning valve #942062
03/03/11 07:40 PM
03/03/11 07:40 PM
SW PA
chett Offline OP
chett  Offline OP
SW PA
I am having no luck trying to find a brake proportioning or metering valve for my 1984 Dodge B front 250 VAN. (6400 GVW)
Also do not know if it has a distribution valve separate or integral.
Please advise as to possible contacts on this subject and include any tech info you think I WILL NEED IN YOUR ANSWER.
I have also been asked to determine if mine is a B 1,2 Or 3 fro correct application.
Dealer is no help here.
Can yo uhelp?
single choice
Votes accepted starting: 03/03/11 06:39 PM
You must vote before you can view the results of this poll.
Re: 1984 Ram VAN 250 brake proportioning valve [Re: chett] #942063
03/03/11 10:22 PM
03/03/11 10:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What does your vin start out with?
