Frame tigh install ? #942058
03/03/11 06:05 PM
03/03/11 06:05 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
Any reason i should not install my frame tighs with the wieght of the motor and trans out and sitting on jack stands under the suspension, seems to be a bit contraversial around here.
Re: Frame tigh install ? [Re: Lew] #942059
03/03/11 09:27 PM
03/03/11 09:27 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
unless its a rusted out hull, it will not matter.
Re: Frame tigh install ? [Re: Randy..] #942060
03/03/11 10:49 PM
03/03/11 10:49 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
are you cutting the floor? if you are make sure the car is supported well
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Frame tigh install ? [Re: Stroker Scamp] #942061
03/04/11 08:26 AM
03/04/11 08:26 AM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
This a weld at each end rail, and no rust.
