5/16 to 3/8 Fuel line upgrade #941845
03/03/11 09:42 AM
03/03/11 09:42 AM
cbusters Offline OP
cbusters  Offline OP
69 RR 383. Fuel pump to carburetor line.I want to get a 3/8 line and a high volume fuel pump without changing to the separator like the 440 has. I want to keep with the same design as original solid tube to the AVS(Edelbrock Series). Anyone done this with a prefabbed piece? Don't really want to bend one myself. Who makes it?
Re: 5/16 to 3/8 Fuel line upgrade [Re: cbusters] #941846
03/03/11 10:18 AM
03/03/11 10:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why the upgrade? the 5/16 line will be fine unless the 440 has a bunch of work. I've seen 440 cars run 11's w/ 5/16 line. If you have a mild 440 build upgrade your Fuel pump and be done.
Coming soon!!!!
Re: 5/16 to 3/8 Fuel line upgrade [Re: cbusters] #941847
03/03/11 10:28 AM
03/03/11 10:28 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
If it's the original 5/16, you may want to change it anyway, or even if you just want to. He's probably right that it's enough (5/16), but why not if you feel it will make things better.
I special ordered from Fine Lines, or you could also contact Inline. I had a 1/2 inch made for a 71 B that is normally not sold. The 3/8 is from a HEMI anyway in your year. You'll need to order a sender as well, you can get that anywhere. The line will go as far as the pump, you can make the changes from there, although you may have to bend your own from the pump to the carb.
Re: 5/16 to 3/8 Fuel line upgrade [Re: DANA60] #941848
03/03/11 10:46 AM
03/03/11 10:46 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Keep in mine Fine Lines and the others bend the line in 1/2 for shipping and you will have to straighten it...and it will NEVER be completely straight. If you can pick one up at a show or event before they bend it in 1/2.
Re: 5/16 to 3/8 Fuel line upgrade [Re: Mr.Yuck] #941849
03/03/11 12:09 PM
03/03/11 12:09 PM
NY usa
540challenger Offline
NY usa
The bends they put into them are very wide and gradual and very easily to get out kink free and straight. I did this with 1/2 SS that was a bear mild steel would be much easier then the SS in 1/2 but it can be done. They usually bend them in 3 areas to fit in a box it would be nice to get one not bent however shipping cost would be huge and if you pick it up yourself you better have a full size van or something close to transport the thing
Re: 5/16 to 3/8 Fuel line upgrade [Re: 540challenger] #941850
03/03/11 12:28 PM
03/03/11 12:28 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
well the bend in mine wasn't "easy" to remove and there is still a wiggle in the line. I would have rather had it sent in 2 pieces.
Coming soon!!!!
Re: 5/16 to 3/8 Fuel line upgrade [Re: Mr.Yuck] #941851
03/03/11 12:31 PM
03/03/11 12:31 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have installed 2 of them, the bend is easy to get out without any damage.
Re: 5/16 to 3/8 Fuel line upgrade [Re: Mr.Yuck] #941852
03/03/11 12:33 PM
03/03/11 12:33 PM
NY usa
NY usa
What is a wiggle in a line you mean it is moving ????
Re: 5/16 to 3/8 Fuel line upgrade [Re: 540challenger] #941853
03/03/11 12:41 PM
03/03/11 12:41 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i think he means a squiggle (slight s'ing) and i had the same problem. not really a problem more like an annoyance
Re: 5/16 to 3/8 Fuel line upgrade [Re: mikemee1331] #941854
03/03/11 12:53 PM
03/03/11 12:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what he said, it's just a tad not straight, no effect on flow
Re: 5/16 to 3/8 Fuel line upgrade [Re: Mr.Yuck] #941855
03/03/11 12:55 PM
03/03/11 12:55 PM
NY usa
NY usa
Ok i was thinking the whole line was moving in a spot i was like LOL
Re: 5/16 to 3/8 Fuel line upgrade [Re: 540challenger] #941856
03/03/11 06:22 PM
03/03/11 06:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Also depends on what you are doing. Sustained RPMs cause more fuel demand.
At Willow Springs Tim Herren's old 71 Dart with just a 360, headers, and MP 528 solid cam, 830 Holley, "ran out of gas". Now that's a road course and particularly one of the fastest and longest straights around. On the street he had no issues.
Troy made mine with large radius bend and no right angle adapters. His idea was to have smooth flow and no sharpe turns to create turbulence and cavitation. And to keep it away from the hot motor. I will be adding firesleeve insulation.
Re: 5/16 to 3/8 Fuel line upgrade [Re: autoxcuda] #941857
03/04/11 08:41 PM
03/04/11 08:41 PM
cbusters Offline OP
cbusters  Offline OP
The car is being assembled and I have the opportunity to build it the way I want. I had thought there was an article a while back about a direct replacement 3/8 that was routed the same as the 5/16. My finished vision is a car with mostly unrecognizable changes that improves the performance. The simple upgrade would be to use the 440 lines and deal with the separator, but that is too obvious of a change that looks like a mistake was made. So, I want to do it the best way without having to bend it myself. I will if that is the last resort. Somebody has to remember the story.
1/2 will look too obvious.
I prefer to not have any squiggles or kinks. The car would run like a Chevy just to get back at me!
Re: 5/16 to 3/8 Fuel line upgrade [Re: cbusters] #941858
03/05/11 12:11 AM
03/05/11 12:11 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
As others have stated...You'll need to start with the 3/8 sender or the rest is'nt worth the upgrade...Anyhow...The 3/8 front to rear line is easy, they already make that...The tubing manufacturer can make you the 5/16 routing using the 3/8 tubing from the fuel pump to carb if you want one...I've had custom lines made up like that and they've been very reasonable on the price...
