what do you think it will run? #941661
03/02/11 11:17 PM
03/02/11 11:17 PM
mesa arizona
moturbopar Offline OP
mesa arizona
Hi all I know alot of people have probably asked this question, but looking to get an idea of what you guys think my car is capable in the 1/4
69 barracuda 3480 with me in it.
360 9.2 compression
ported smog "596" heads 2.02 valves 1.60 exhast
comp xe268 cam
1.5 roller rockers
ported M1 single plane intake
650 holley
1 5/8" long tube headers
2.5 summit exhaust
904 trans
coan 2800 stall converter
8 3/4 3.55 gears.
c body rear shocks
stock springs, poly bushings
adjustable pinion snubber,
front is all stock rebuild, but looking at adjustable drag shocks
subframe connectors, reinforced torque boxes.
265/50 16 drag radials
And 100 to 150hp shot of nitrous
Im hoping the car is capable of low 13s maybe high 12s without the nitrous, and maybe mid to low 12s with the 100 shot?
Anything you guys think that I should change? I was considering 3.91 gears, but dont know.
Re: what do you think it will run? [Re: moturbopar] #941662
03/02/11 11:21 PM
03/02/11 11:21 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
At our elevation (2800ft) I would say mid to high 13's with that setup.
Re: what do you think it will run? [Re: moturbopar] #941663
03/02/11 11:22 PM
03/02/11 11:22 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
i can only tell you what I have and what mine runs, you can use it as a gauge if you want
66 cuda
3430 - weight
360 std bore - 9.4:1 w / KB 107's
stock 596 heads with stock 1.88 intake valves
mopar 474 lift cam
eddy street ram with 2 holley 390's
904 w/ mopar 175k converter
3.23's
26x9 slick
12.80@ 108
i swapped the converter for a dynamic 9.5" 3800 stall
I went to a low gear set
I also went to a 24.5x 8" slick
12.56 @ 106
Re: what do you think it will run? [Re: DJVCuda] #941664
03/03/11 01:51 AM
03/03/11 01:51 AM
mesa arizona
mesa arizona
Do you guys think the 100 shot would getme into the low 12 to mid 12s?
Re: what do you think it will run? [Re: moturbopar] #941665
03/03/11 03:44 AM
03/03/11 03:44 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Mid to high twelves-yes.
Re: what do you think it will run? [Re: RemCharger] #941666
03/03/11 03:50 AM
03/03/11 03:50 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
More cam/convert./carb/gear. = more smiles.
Re: what do you think it will run? [Re: moturbopar] #941667
03/03/11 01:45 PM
03/03/11 01:45 PM
jersey
Spaceman Spiff Offline
jersey
My non mopar daily driver weighs 4430 with me in it. Stock 260hp engine. With just headers a good exhaust a 3600 stall and 3.73 s it goes 14.00 @ 98-99mph. This is on a 17inch drag radial.1.82 60 ft.
I should hope a much lighter car with more work would be much faster.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: what do you think it will run? [Re: Spaceman Spiff] #941668
03/03/11 02:45 PM
03/03/11 02:45 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
That smells of a late model, with a "net" 260 hp plus whatever the headers add and better automatic (1st gear).
Back in the day, with his cam, carb, converter and gearing............
high 13's on street tires, low 13's, mayyyyybe high 12's with slicks, tweaked and powertuned to fullest extent.
Too many variables to debate here, just take it to the track and report back. Have fun, that's what it's about.
Re: what do you think it will run? [Re: Dean_Kuzluzski] #941669
03/03/11 05:57 PM
03/03/11 05:57 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
BE very careful if you want the engine to last Putting a 100 shot of nitrous on your motor. Nitrous that is not right will nlow up an engine real fast. Is it worth it to try? Just and old fart who has spent too much money over the years on great ideas without knowing the whole story.
Re: what do you think it will run? [Re: moturbopar] #941670
03/03/11 06:33 PM
03/03/11 06:33 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
The intake is a poor choice with the small cam. I'd use an RPM intake with a better cam. 3.91 gears would be a good choice.
Re: what do you think it will run? [Re: goldmember] #941671
03/03/11 06:37 PM
03/03/11 06:37 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
my 4400LB C body barge goes 14:90,s untuned bone stock.. 3:55,s in place of howling 3:23 though.. dan
Re: what do you think it will run? [Re: moturbopar] #941672
03/03/11 07:36 PM
03/03/11 07:36 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Well, Id say a "clean" 100 shot will get you low 12s, if not better....
Big Squeeze (Wayne Smothers) has customers cars knocking off 1.5-2 seconds on clean 200 shots. These cars were in the bottom 11s on motor, high 9s on the giggle gas.
Before you go juicin it, make sure you get a jet combination from Monte Smith. The old tune charts are fuel fat and will kill a motor in short order.
Any idea what your ring gaps are?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: what do you think it will run? [Re: Von] #941673
03/03/11 08:03 PM
03/03/11 08:03 PM
mesa arizona
mesa arizona
Thanks for the reply guys. The M1 seemed to work well on the 318 with the nitrous.
I keep thinking about going bigger on the cam, gears and converter, but I think this combo will be nice and streetable. I am considering going to a 9.5" 3500 converter, but will probably try out the coan converter first. If I can get the car to run 12s with the nitrous I will be happy.
As for the ring gaps, I havnt set them yet I was thinking .025 top and
.028 second, what would you guys reccomend?
Re: what do you think it will run? [Re: moturbopar] #941674
03/03/11 08:15 PM
03/03/11 08:15 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
13's on the motor and 12's on the juice is my guess. Good luck...update whenever you get it to the track.
Re: what do you think it will run? [Re: moturbopar] #941675
03/03/11 08:57 PM
03/03/11 08:57 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
If 12's on spray is enough for you then you'll have no problems.
Re: what do you think it will run? [Re: goldmember] #941676
03/05/11 04:38 AM
03/05/11 04:38 AM
mesa arizona
mesa arizona
Well i have a new .484 cam available to me but would it be as fun to drive on the street? I also have someone interested in trading me the .484 for an XE274. The problem is my heads have the comp cams 901 single springs and the xe274 calls for comps dual springs. I dont want o spend more $$$ on springs. So should I just stick with the xe268?
Re: what do you think it will run? [Re: babarracuda] #941677
03/05/11 05:03 PM
03/05/11 05:03 PM
california
drumcat Offline
drumcat  Offline
california
I agree,nothing but trouble....as i rebuild because of melted pistons.
