PRW rockers the good the bad and the ugly #941084
03/02/11 02:06 AM
03/02/11 02:06 AM
PA
W
w7smallblock Offline OP
W
PA
PLEASE DO NOT RESPOND TO THIS POST IF YOU PERSONALLY HAVE NO!!! EXPERIENCE WITH THESE ROCKERS, THANK YOU NOW FOR THE ?
I'm looking at the prw 1.6 smallblock stainless rockers has anyone used them if so you're thoughts. This is for a BUDGET 408 with about 130-140 seat pressure and 330-350 open. Has anyone checked to see if the rocker ratio is close to advertised.
Thanks for your time, Jim
Re: PRW rockers the good the bad and the ugly [Re: w7smallblock] #941085
03/02/11 02:29 AM
03/02/11 02:29 AM
AndyF Offline
AndyF  Offline
I've used them. The ratio on my set was closer to 1.5 than 1.6.
Re: PRW rockers the good the bad and the ugly [Re: AndyF] #941086
03/02/11 03:02 AM
03/02/11 03:02 AM
Saint John
Canuck Offline
super gas
Canuck  Offline
super gas
Saint John
i have about 70 passes on a set in a 480hp 360. Turning it to 7000rpm and no issues. .600 lift flat tappet.
thought they wouldn't last a weekend....still in there..knock on wood
keep an eye on the lash though they can move around
Re: PRW rockers the good the bad and the ugly [Re: Canuck] #941087
03/02/11 03:09 AM
03/02/11 03:09 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Why is the lash moving around??
Re: PRW rockers the good the bad and the ugly [Re: AndyF] #941088
03/02/11 02:09 PM
03/02/11 02:09 PM
Finland
mopster Offline
mopster  Offline
Finland
Same here.
Re: PRW rockers the good the bad and the ugly [Re: mopster] #941089
03/02/11 07:45 PM
03/02/11 07:45 PM
Amherst,NY
challengermike Offline
Amherst,NY
I have the stainless 1.5s on my bigblock and they are fine.Only running a 540/557 lift solid cam though.They are bushed and not roller bearings.Im pretty sure they are made by CAT.There was a very slight ink stamp on the bottom that looks like the cat symbol.
Re: PRW rockers the good the bad and the ugly [Re: w7smallblock] #941090
03/03/11 12:25 PM
03/03/11 12:25 PM
PA
W
W
PA
Thanks for the replies and not turning this into a bash on the parts in question from people with no experience with these. I think i'm gonna give them a try.
