Trailer questions #940756
03/01/11 07:21 PM
03/01/11 07:21 PM
florida
hemifw Offline OP
hemifw  Offline OP
florida
Is it better to have a winch or a drivers escape side door to get your car in and out of the trailer? What do most of you guys do to get your car in and out? Im trying to decide what to get for my truck which may be a little wider than a car.
71 Demon
Re: Trailer questions [Re: hemifw] #940757
03/01/11 07:28 PM
03/01/11 07:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Winching in a car/truck ALL THE TIME gets to be a pain
in the butt so if I was buying a trailer for that ride
I'd go with the escape hatch... but you have to watch,
some of them dont go low enough so you can open the
door so then you climb out of the window... plus you
need to have it placed in the right spot..... either
way I would still have a winch
Re: Trailer questions [Re: hemifw] #940758
03/01/11 07:40 PM
03/01/11 07:40 PM
Locomotion Offline
Locomotion  Offline
I've had a winch, but never hooked it all up! Luckily, I haven't had any breakage but have come-a-longs also, just in case.
Escape door is nice especially if I just need quick access to the car from the driver's side. But with an A-body, I don't have to use it to get in and out, so I carefully drive it in.
As for door clearance, I did make a "platform" for the slicks to drive up on and located where the tires sit when it's all tied down. It's about 3" x about 12" square with bevels on both sides and covered with diamond plate. It helps the car door clear the bottom of the trailer escape door with plenty of room and helps locate the car when driving in.
Re: Trailer questions [Re: Locomotion] #940759
03/01/11 10:22 PM
03/01/11 10:22 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I have both, but have yet to use the winch. ::knocking on wood::
Re: Trailer questions [Re: gsmopar] #940760
03/01/11 10:37 PM
03/01/11 10:37 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Like Mike said, winching it in and out is a pain in the a**, but with a 102" wide Pace Shadow and a '72 E body, a winch is a must. Doors have lexan that does not open and with the way the window and door curves and the lenght of the doors I can't even reach in far enough to put it in park.
So its winch it in, and 4 "Xed" straps, and away we go. Also the car sits low enough that the door wouldn't clear the fender anyway with out raising the car in the trailer.
Funny story, I ordered my trailer, then went to Elkhart, In picked it and brought it home. As soon as I got home I opened the door and drove my car inside the trailer, set there a minute, backed it out, went inside the shop and called Jegs, "send me a winch, and hurry". I went racing that weekend using my old open trailer with a brand new enclosed sitting in the drive way. I didn't think that one all the way through.
Brian Dunnigan
Re: Trailer questions [Re: '72CudaRacer] #940761
03/01/11 10:51 PM
03/01/11 10:51 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
One thing that might help is to pull the car in straight, then crank it hard right so its sitting somewhat sideways.. It gives us just enough wiggle room to slide into the seat.. while sucking in our gut..
Re: Trailer questions [Re: Jeepmon] #940762
03/01/11 11:30 PM
03/01/11 11:30 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I must be goofy: I use a winch even on my open trailer and with whatever car I'm hauling. Don't have to start the car, I put it right where I want it, and I can watch around the car when unloading (I use a 30-foot cable & controller). It also holds the car when I go under it for the tie-downs. Guess I got used to it when I was hauling cars for people, so I don't think twice about it.
Re: Trailer questions [Re: Jeepmon] #940763
03/01/11 11:30 PM
03/01/11 11:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just pull in close to the right inner fender(straight in)
and that leaves me plenty of room with my LITTLE car
to get out... I dont know how people with a big B-body
can open the door enough ... even with a skinny driver
Re: Trailer questions [Re: Jeepmon] #940764
03/01/11 11:37 PM
03/01/11 11:37 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Ya'll may think this is crazy but it works for me. It's been years since I've been able to get in and out of my car while in the trailer from the drivers doo, the fixed windows make it almost impossible.. However I drive my car in a lttle tight on the drivers side. I then can exit the car on the passenger side by putting my left leg out and squeezing out the door. It works great, try it!!!!
Re: Trailer questions [Re: hemifw] #940765
03/01/11 11:44 PM
03/01/11 11:44 PM
I use a 4500 lb super winch with a 30 ft. cable, I load the car to the right side of the trailer so I can walk down the left side to watch the front and the right inner fender on the trailer as I load it I have used a 2500 lb winch in the past on another trailer and it would get real slow when the front and rear tires where on the ramp and on the dove tail at the same time The 4500 lb winch will pull the car in with it in park on dirt , Done that accidentily several times
Re: Trailer questions [Re: Locomotion] #940766
03/01/11 11:53 PM
03/01/11 11:53 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Myron, how far did you go at the Madris Gras?? Max Williamson
Re: Trailer questions [Re: Cab_Burge] #940767
03/01/11 11:55 PM
03/01/11 11:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
But Cab.... is that reaching in a open window to steer
it.... when I would winch my car in I would have
to steer it by moving the tires... not bad on my car
but if the car is heavy you would most likely need
to do it rolling
Re: Trailer questions [Re: Cab_Burge] #940768
03/01/11 11:58 PM
03/01/11 11:58 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I put studs in the door where the window struts attach. Using wing nuts allows me to remove the drivers window with little effort.
Makes climbing out the window simple as pie.
However, I do have a winch and unfortunately it has come in handy to many times.
Re: Trailer questions [Re: WILD BILL] #940769
03/02/11 10:08 AM
03/02/11 10:08 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I`ve always used a winch with a remote control. Aim the car straight up the ramp and into the trailer , stop at the wheel chocks . Easy as pie , cheaper than the escape hatch AND more secure.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Trailer questions [Re: chryco] #940770
03/02/11 11:43 AM
03/02/11 11:43 AM
florida
hemifw Offline OP
hemifw  Offline OP
florida
Thanks for the help everyone, I usually go racing by myself ,so is it hard to get the car out of the trailer with only having a winch ?? I mean does it just roll out on its own or do you have to jack up the front of the trailer?
Sorry for the newbie questions..I just dont want to buy something , then get to the track and have a problem getting the car out of the trailer lol..
71 Demon
Re: Trailer questions [Re: hemifw] #940771
03/02/11 11:53 AM
03/02/11 11:53 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Kinda depends on the ground at the time as to how the car will roll out. Usually no problems until the back tires are off the ramp and then sometimes I'll have to give it a push.
However, mostly by that time the door is clear enough that you could unhook and drive out the rest of the way.
If you go by yourself mostly I would recommend either a long lead on the winch remote or a wireless remote you can be where ever you need to to control the car while pulling it in.
Re: Trailer questions [Re: WILD BILL] #940772
03/02/11 01:04 PM
03/02/11 01:04 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
I like my winch, I'm way less likely to scrape the wall of the trailer while loading with a winch after having a couple beers!!
Re: Trailer questions [Re: Blucuda413] #940773
03/02/11 01:32 PM
03/02/11 01:32 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
this is a great post at just the right time. I'm going to pick up our new 28 footer saturday and I wasn't sure how to get the car in. My butt isn't fitting out the driver side of the cuda with the roll bar in the way but.... I think the climbing out the passenger side just might work.... if not. winch it is!
Re: Trailer questions [Re: hemifw] #940774
03/02/11 01:54 PM
03/02/11 01:54 PM
Locomotion Offline
Locomotion  Offline
Some enclosed trailers have a little dove-tail in the last several feet of the trailer where the back tires may end up on the edge. That helps roll it out, but sometimes it needs a little help.
If you need to give the car a little push to get it rolling while in it, watch how far you driver's door is open. I had a rude reminder.
Re: Trailer questions [Re: hemifw] #940775
03/02/11 02:28 PM
03/02/11 02:28 PM
As already said about the car backing down out of the trailer, if it has a dove tail like mine I have to push it maybe 1 or 2ft. to get it rolling down onto the door when the trailer is level I do use a electric tongue jack and I usually unhook the trailer as most of the races I go to are two days so the trailer is raised up in the front some to start with usually . My trailer is a 24ft. Pace and the car is a 1971 Duster, I load the car so the rear of the car is in barely enough(six to 10 inches to the rear bumper) to clear the rear door, which leaves a lot of romm in front of the car It also places the center of the car over both axles, making the trailer pull really great
