Re: Best 340 cam/intake combo
[Re: MonGoo$e]
#940742
03/01/11 08:55 PM
03/01/11 08:55 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Father knows best!! the old Ultradyne 223/231 on 108 in at 102 would be about as big as I'd go there and that'll work with the vert and gears, the LD 340 is a good one but if the crosswind is the airgap clone you won't tell a bit of difference between them Overcam and undergearing a short stroke motor is not a good idea, if it was a stick and 4.10's the 508 would work a good bit better but I'd step that up one notch of the ultradyne chart to the 231/239 which is my favorite hot street 340/360 cam.
[Re: 392charger]
#940744
03/01/11 09:22 PM
03/01/11 09:22 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
""a mild stall wich power brakes to around 2400."" Have you thought about a performance converter with the cam/intake swap?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: calrobb2000]
#940748
03/02/11 10:15 AM
03/02/11 10:15 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
cam, I'd used hughes #1110 springs and a lunati voodoo 60403.
intake, I'd probably go to the LD
converter, I'd go to something in the 2500RPM stall range.
[Re: 392charger]
#940755
03/05/11 06:52 PM
03/05/11 06:52 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
My son wants more power and a bigger cam in his 71 340 Demon. Currently has an old hyd 268 Magnum cam (180 lbs crankng compression)and a Crosswind (Professional Products?) intake. 99% street car with 727 auto, 355 gears, Dougs headers, manual brakes, mopar performance dist, 770 street avenger holley and a mild stall wich power brakes to around 2400. I told him to install the LD340 intake we already have but he wants to put a single plane on it along with a Mopar hyd 508(?) cam/lifter kit while retaining the stock rockers and springs. I'm not sure this would be the hot set and would need new springs at least, so I am asking for your proven combos. Thanks Moparts members
You are already on the right path! Tweak the ignition a bit more and "optimize" your present setup, BEFORE you start making other changes. It may surprise you for the better!! The bigger '508 cam and single plane WILL need the higher stall converter and gears to increase performance BUT it will reduce the "streetability" of the combo. Depends on how fast vs how far (in cruising) he wants to go!!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
