dodge v-10 question #939481
02/28/11 12:12 AM
02/28/11 12:12 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
has anyone has any experinces with dodge v-10 motors good or bad was looking @ 1 but don't know much about them.........Thanks
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: dodge v-10 question [Re: 67mprfan] #939482
02/28/11 12:14 AM
02/28/11 12:14 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Great for power, but not so good for gas mileage. My 98 averages around 10 mpg. Thats towing or regular driving.
Re: dodge v-10 question [Re: moparguy7074] #939483
02/28/11 12:18 AM
02/28/11 12:18 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
yes forgot to mention truck would be used for towing and plowing a guy at work told me they go threw tranny's pretty easy
Re: dodge v-10 question [Re: 67mprfan] #939484
02/28/11 12:22 AM
02/28/11 12:22 AM
Rudolph, Ohio
Rudolph, Ohio
No worse than any other older Ram. Depends on how it was maintained and used. I have a 98 2wd 2500 with 145k and the trans still works good. Dang it, I just jinxed myself.
Re: dodge v-10 question [Re: 67mprfan] #939485
02/28/11 09:08 AM
02/28/11 09:08 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
this list of Ram engine TSB's shows the known V10 problems:
http://dodgeram.info/tsb/group_09.htm
V10s seem to have more cracks in cylinder walls than V8s, at least as reported in internet forums
Re: dodge v-10 question [Re: 360view] #939486
03/01/11 05:27 PM
03/01/11 05:27 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Thanks for the info
Re: dodge v-10 question [Re: 67mprfan] #939487
03/01/11 07:06 PM
03/01/11 07:06 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The main reason they go thru transmissions is because many plow jockeys shift from drive to reverse , and vise versa, while the truck is STILL MOVING .
Re: dodge v-10 question [Re: 67mprfan] #939488
03/02/11 03:02 AM
03/02/11 03:02 AM
SoCal
gthomas Offline
mopar addict
gthomas  Offline
mopar addict
SoCal
I towed with a QC 4x4 2500 V10 and 5 speed manual and always averaged 12.5mpg towing my 11,000 pound 5th wheel trailer (Yellowstone to Los Angeles at least twice a year). Never had any engine problems, but had to change the clutch once. Always towed around 58 - 60 mph on the freeway. At first I towed faster but the mileage was terrible so I learned to keep it slower.
Re: dodge v-10 question [Re: gthomas] #939489
03/02/11 10:02 AM
03/02/11 10:02 AM
USA
3
360view Offline
360view  Offline
3
USA
one experiment I always wanted to try
would be get two V10 Rams
one manual transmission
one 47/48 automatic
... and then get a (rare) 3.06 ratio Dana ring and pinion axle that could be swapped in either
Doing at least two
'convoy style' MPG tests
over 300 miles or so on the highway
on empty trucks
at a steady speed would show whether
the 'gas hog' reputation of the V10
is partly due to the overdrive ratio of the drivetrain.
After each test the 3.06 axle would be swapped to the other truck.
It never made engineering sense
that the same 0.69 ratio overdrive
used on the 3.9 V6 Rams
was also used on the 8L V10 Rams
When the Viper V10 trucks were given the 0.50 ratio top gear with the T56 manual, it made a lot more sense
The Allpar article on the 1994-2001 8L iron V10 is a good read:
http://www.allpar.com/mopar/V10.html
notice that they emphasize how they designed-in 1200 rpm Torque capability
sample quote
"Resonance in the 25-inch primary runners enhanced low speed torque, with peak torque as low as 1200 rpm."
end quote
Yet at normal highway speeds
with a 0.69/3.55 ratio drivetrain
you can't make use of that low rpm torque to improve light load cruise?
