Please identify this '70 'Cuda rubber gasket #939055
02/27/11 05:26 PM
02/27/11 05:26 PM
NW/Indiana - Chi town
ricomondo Offline OP
Not sure what this gasket is called or where to find one (vendor)?
All I can seem to find is the fuel filler neck gasket thats back by the tail panel.
GY3 71 Demon 340
Re: Please identify this '70 'Cuda rubber gasket [Re: ricomondo] #939056
02/27/11 05:31 PM
02/27/11 05:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I don't know what is going on there exactly, there appears to be an extra piece sandwiched in between the vapor separator & the trunk floor... There should be the vapor separator, a foam gasket which Jim makes & then the trunk floor...
Re: Please identify this '70 'Cuda rubber gasket [Re: ricomondo] #939057
02/27/11 06:34 PM
02/27/11 06:34 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: Please identify this '70 'Cuda rubber gasket [Re: ricomondo] #939058
02/27/11 08:33 PM
02/27/11 08:33 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Is that a Calif car?? 49 states had a much smaller vent tube.
Re: Please identify this '70 'Cuda rubber gasket [Re: formula_s] #939059
02/27/11 10:06 PM
02/27/11 10:06 PM
Thank you guys!
The pan & extension are gonna be replaced shortly, so I wanted to make sure I had the right seals.
Also, yes, this is an LA built 'Cuda with ECS.
GY3 71 Demon 340
