Re: Speedometer gear change?
[Re: b5rr]
#938734
02/27/11 04:18 AM
02/27/11 04:18 AM
RapidRobert
Not sure if '65 has changed over to the larger gears or not. The earlier ones have fewer teeth selections avail & might need to use one of those adapter gismo's that let you change the ratios w it.
[Re: RapidRobert]
#938735
02/27/11 08:26 AM
02/27/11 08:26 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
I know for sure the 4 speeds have the old gear style.Pretty sure the autos do also.The gears arent as avaliabe as the new style.I was looking for one for my 65 B body.The 3.23 one dosent work real well when I have the 4.88s in it.With the 3.91s I know the speedo is off about 20 percent fast.Rocky
Chrysler Firepower
[Re: b5rr]
#938738
02/27/11 11:24 AM
02/27/11 11:24 AM
RapidRobert
Look on the side w the speedo cable and the early one has a smaller hole/assy and a flat plate that bolts it in as opposed to the '66 up one w the larger alum speedo adapter w the horseshoe clamp. That'd b a good start figuring how much error you have & if you do source the correct gear which'll make the odo correct (do measure ACTUAL tire dia w a piece of flat stock on top of the tire & measuring rollout is even better) & interstate mile markers are perfect for checking it (odo). most of the time the speedo will then also come in correct (check w digital road side speed signs)but the speedo is a sort of seperate function & if not correct the speedo head will need to go to a speedometer specialty shop to recalibrate but as you know the pinion has to have the correct teeth count 1st.
[Re: b5rr]
#938739
02/27/11 06:44 PM
02/27/11 06:44 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The '65 and earlier transmissions use the smaller pinion with a range of only 16-21 teeth.
When using a calculator, the early drive gear has 8 teeth instead of the 13 teeth on the '66 and later.
[Re: John_Kunkel]
#938740
02/27/11 06:56 PM
02/27/11 06:56 PM
RapidRobert
John is that tooth count the same for 904's?
[Re: John_Kunkel]
#938744
02/27/11 09:30 PM
02/27/11 09:30 PM
RapidRobert
Thank you John, I put it in my notes
