my poormans dyno #938540
02/26/11 08:54 PM
02/26/11 08:54 PM
glendora, ca.
Deepockets Offline OP
glendora, ca.
dont really want to spend the money for dyno time. but i did want to make sure alls well before it goes in the car. i just have to hook up the ignition and i will fire. pockets are empty now!
Re: my poormans dyno [Re: Deepockets] #938541
02/26/11 08:59 PM
02/26/11 08:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
We call them break in stands
Re: my poormans dyno [Re: MR_P_BODY] #938542
02/26/11 09:37 PM
02/26/11 09:37 PM
SoCal
Brian Hafliger Offline
SoCal
Re: my poormans dyno [Re: Brian Hafliger] #938543
02/26/11 10:53 PM
02/26/11 10:53 PM
Change your USERNAME to shallowpockets or shortpockets.
Re: my poormans dyno #938544
02/26/11 10:56 PM
02/26/11 10:56 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
love those valve covers!
Re: my poormans dyno [Re: tjmarcus1] #938545
02/26/11 11:06 PM
02/26/11 11:06 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
What about transmission lube?
Re: my poormans dyno [Re: Leigh] #938546
02/26/11 11:20 PM
02/26/11 11:20 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yep better have fluid in that trans if you plan on running more than just a few seconds.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: my poormans dyno [Re: Deepockets] #938547
02/26/11 11:32 PM
02/26/11 11:32 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Heck, I have one of those.
Re: my poormans dyno [Re: S/ST 3040] #938548
02/26/11 11:59 PM
02/26/11 11:59 PM
glendora, ca.
glendora, ca.
well, everything went good, sounds good. good oil pressure. i'll run it a little more tommorow and then go over the valves. the trans does'nt have the converter in in, so nothing's spinning. thanks to all the helpfull info from all you guys and the shops that gave me sound advice that aided me in this build.
Re: my poormans dyno [Re: Deepockets] #938549
02/27/11 10:49 AM
02/27/11 10:49 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
good luck
Re: my poormans dyno [Re: fishy340] #938550
02/27/11 11:32 AM
02/27/11 11:32 AM
Lehigh Acres, Florida
rickstershemi Offline
can you post some pics and info of that stand....looks pretty simple to build....am looking to build somethin similar
Rickster
Re: my poormans dyno [Re: rickstershemi] #938551
02/27/11 07:20 PM
02/27/11 07:20 PM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
Here's the one I built.
Cut the torque convertor in half for starting, tranny is hollow.
Everythings adjustable and we've had Hemi's, big block and small blocks on it. Works great.
Love to find a water brake to be able to seat rings.
Just remember with no load it's easy to over rev it.
Re: my poormans dyno [Re: six-barrel] #938552
02/27/11 07:31 PM
02/27/11 07:31 PM
Montgomery, PA
dodge340dart Offline
Montgomery, PA
Here is the poorman dyno (breakin stand) I made for all my slant sixes. I just use a flywheel and a manual transmission bellhousing.
http://www.youtube.com/watch?v=vmS2ETLlEps
Chris
2011 & 2012 Beaver Springs Dragway Outlaw Street Champion 2012 BSD Friday Street Racer Driver of the Year 3-time Jr. Stock Eliminator 2-time Mean Street Eliminator '69 340 Dart 1.500 60ft, 11.359et, 117.08mph
Re: my poormans dyno [Re: Deepockets] #938553
02/27/11 09:12 PM
02/27/11 09:12 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
????? No converter? how do you start it? I thought mopar had the ring gear on the converter
Re: my poormans dyno [Re: rowin4] #938554
02/27/11 09:44 PM
02/27/11 09:44 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Does that look like a Torqueflight to you?
Re: my poormans dyno [Re: six-barrel] #938555
02/27/11 11:40 PM
02/27/11 11:40 PM
glendora, ca.
glendora, ca.
wow, thats a nice one. i knew i was most likely going to cut mine up when done, so i did'nt go to the extreme.
Re: my poormans dyno [Re: Deepockets] #938556
02/27/11 11:44 PM
02/27/11 11:44 PM
Same here, that's a nice one, but don't really have the room to store it and after seeing a couple of the lighter framed one's believe I will just adapt my engine cradle for now
Rickster
Re: my poormans dyno [Re: dusturbd340W5] #938557
02/27/11 11:50 PM
02/27/11 11:50 PM
tn
robnbird Offline
robnbird  Offline
tn
you better also keep trans fluid in that trans
Re: my poormans dyno [Re: robnbird] #938558
02/27/11 11:54 PM
02/27/11 11:54 PM
glendora, ca.
glendora, ca.
ronbird, it has the jw flywheel to accept the turbo 350-400 converter. i just did'nt put the converter in so the trans imput shaft does'nt spin.
Re: my poormans dyno [Re: @#$%&*!] #938559
02/28/11 02:49 AM
02/28/11 02:49 AM
rowin4 Offline
rowin4  Offline
What's a Torqueflight? Is that one of those transmissions you don't have to shift ?
