Re: my poormans dyno
#938544
02/26/11 10:56 PM
02/26/11 10:56 PM
Posts: 2,119 sc
tjmarcus1
sc
[Re: rickstershemi]
#938551
02/27/11 07:20 PM
02/27/11 07:20 PM
Posts: 153 Wpg, Mb, Canada
six-barrel
Wpg, Mb, Canada
Here's the one I built.
Cut the torque convertor in half for starting, tranny is hollow.
Everythings adjustable and we've had Hemi's, big block and small blocks on it. Works great.
Love to find a water brake to be able to seat rings.
Just remember with no load it's easy to over rev it.
[Re: six-barrel]
#938552
02/27/11 07:31 PM
02/27/11 07:31 PM
Posts: 148 Montgomery, PA
dodge340dart
Montgomery, PA
Here is the poorman dyno (breakin stand) I made for all my slant sixes. I just use a flywheel and a manual transmission bellhousing. http://www.youtube.com/watch?v=vmS2ETLlEpsChris
2011 & 2012 Beaver Springs Dragway Outlaw Street Champion
2012 BSD Friday Street Racer Driver of the Year
3-time Jr. Stock Eliminator
2-time Mean Street Eliminator
'69 340 Dart 1.500 60ft, 11.359et, 117.08mph
[Re: Deepockets]
#938553
02/27/11 09:12 PM
02/27/11 09:12 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
well, everything went good, sounds good. good oil pressure. i'll run it a little more tommorow and then go over the valves. the trans does'nt have the converter in in, so nothing's spinning. thanks to all the helpfull info from all you guys and the shops that gave me sound advice that aided me in this build.
????? No converter? how do you start it? I thought mopar had the ring gear on the converter
[Re: rowin4]
#938554
02/27/11 09:44 PM
02/27/11 09:44 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Does that look like a Torqueflight to you?
[Re: six-barrel]
#938555
02/27/11 11:40 PM
02/27/11 11:40 PM
Posts: 939 glendora, ca.
Deepockets
glendora, ca.
wow, thats a nice one. i knew i was most likely going to cut mine up when done, so i did'nt go to the extreme.
[Re: Deepockets]
#938556
02/27/11 11:44 PM
02/27/11 11:44 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Same here, that's a nice one, but don't really have the room to store it and after seeing a couple of the lighter framed one's believe I will just adapt my engine cradle for now
Rickster
[Re: dusturbd340W5]
#938557
02/27/11 11:50 PM
02/27/11 11:50 PM
Posts: 914 tn
robnbird
tn
What about transmission lube?
yep better have fluid in that trans if you plan on running more than just a few seconds.
you better also keep trans fluid in that trans
[Re: six-barrel]
#938561
02/28/11 07:51 AM
02/28/11 07:51 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
If you run it with the trans bolted up and fluid in it, you had better have the yoke in there too, right? I'm almost there myself and have been chompin' at the bit to hear this baby run all winter. I dont want to put it in the vehicle until I know she checks out. I love that stand with the hemi in it.
[Re: Deepockets]
#938562
03/01/11 09:35 PM
03/01/11 09:35 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Good to hear there was no trouble on start-up, the headers look good on that thing.
"Just a Bracket car dressed up like a streetcar"
[Re: cgall]
#938566
03/02/11 01:56 AM
03/02/11 01:56 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
so you better have tranny fluid in it.......and how did you start it again??? sorry ...i had to
