72 RR ROOF STROBE STRIPE #938395
02/26/11 04:48 PM
02/26/11 04:48 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Where can I find placement measurements for install??
Re: 72 RR ROOF STROBE STRIPE [Re: kbcuda] #938396
02/26/11 05:57 PM
02/26/11 05:57 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I just took the measurements off a 71 I'm doing before I removed them but it's at my shop. I'll take a look Monday with the measurements.
E mail me so I can write you back in a couple days.
TWN727@comcast.net
Re: 72 RR ROOF STROBE STRIPE [Re: DANA60] #938397
02/26/11 07:33 PM
02/26/11 07:33 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
It needs to go on tomorrow ...Thanks
Re: 72 RR ROOF STROBE STRIPE [Re: kbcuda] #938398
02/26/11 08:04 PM
02/26/11 08:04 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
There are some drawings here: http://www.roadrunnernest.com/ in the Technical Archive /User Submissions / Tech Drawings area. But I am not sure if they will be of help since they look like 1971 model year drawings.
Common sense is a flower that does not grow in everybody's garden
Re: 72 RR ROOF STROBE STRIPE [Re: Ron_M] #938399
02/27/11 12:24 AM
02/27/11 12:24 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
see below
Re: 72 RR ROOF STROBE STRIPE [Re: kbcuda] #938400
02/27/11 03:42 AM
02/27/11 03:42 AM
Shoreline, Washington
72roadrunnergtx Offline
For 72';
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 72 RR ROOF STROBE STRIPE [Re: 72roadrunnergtx] #938401
02/27/11 01:16 PM
02/27/11 01:16 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
do such drawings still exist for the 73/74 cars?
Re: 72 RR ROOF STROBE STRIPE [Re: Ron_M] #938402
02/27/11 04:49 PM
02/27/11 04:49 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Thanks 72! Are those dimensions on the car from the wheel lip up or the body line? And from the corner of stripe forward to the end of the quarter at the jamb?
Re: 72 RR ROOF STROBE STRIPE [Re: kbcuda] #938403
02/27/11 06:02 PM
02/27/11 06:02 PM
Vertical, about 2 1/4" from the detail/body line. I've seen some variation in the current 72' reproduction strips as to how close they come to that body line. Horizontal, the front edge of the quarter panel measured on a horizontal line parallel to the floor. I swiped that shot of the original stripe from somewhere with those notations, but it comes very close to the Performance Car Graphics stripe I used and their install guide. The problem with the engineering drawings is there is a "zero" point somewhere used as a reference for the fore &aft measurements shown. Rumor is it's around the lower windshield frame somewhere. Without knowing exactly where it is the dimensions are worthless.
