New Hemi Order #937965
02/26/11 01:47 PM
02/26/11 01:47 PM
Smithfield, Rhode Island
Mulehead Offline OP
Mulehead  Offline OP
Last Friday I order a KB hemi aluminum block.Three years a go my old
KB block took a rod out the side.
it was like loosing a good friend.If you guys can understand that.All the parts,bolts,nuts are number and on the shelf and walking by them for years been hard.Well with a little help from the card and money have save,It's looking better.Motor part,Billet crank,Carillo rods,Cp pistons and some of that can change.
Ain't nuthin like a HEMI !
Re: New Hemi Order [Re: Mulehead] #937966
02/26/11 01:48 PM
02/26/11 01:48 PM
Mulehead Offline OP
Mulehead  Offline OP
Re: New Hemi Order [Re: Mulehead] #937967
02/26/11 01:50 PM
02/26/11 01:50 PM
Mulehead Offline OP
Mulehead  Offline OP
Picture 1
Re: New Hemi Order [Re: Mulehead] #937968
02/26/11 03:34 PM
02/26/11 03:34 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Good luck with the new build!
Re: New Hemi Order [Re: Mulehead] #937969
02/26/11 03:53 PM
02/26/11 03:53 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
what caused the kaboom ??
home of the
Sox and Martin Hemi Duster
Re: New Hemi Order [Re: HEMIFRED] #937970
02/26/11 05:43 PM
02/26/11 05:43 PM
Mulehead Offline OP
Mulehead  Offline OP
Thank you Jim,I'm happy.I found the problem after the hole on the side.The rods was older than I thought.My fault should have check them.Look close you see the crack on one of the other rods
