Re: Solid Flat Tappet Differences
[Re: BradH]
#936225
02/24/11 09:41 PM
02/24/11 09:41 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Are you aware that if you use the barbell design w/o bushed lifter bores, you will have NO oil pressure due to excessive oil getting past the cutout in the lifter body?
Brad is correct...
[Re: Cab_Burge]
#936229
02/25/11 11:09 AM
02/25/11 11:09 AM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
We run mopars also they are lighter and been told 5 thousand under size. Comps are heavy . But I had a mishap last year with one ,nobody has seen this happen . We believe the lashcap broke and caused too much lash ,or the hole in lifter made too much lash broke lashcap . witch came 1st chicken or egg.
Pic of it
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: Cuda_Mike]
#936230
02/25/11 01:14 PM
02/25/11 01:14 PM
Posts: 16,928 NC
440Jim
NC
Jim, Here are the dimensions of the lifter.
Thanks Mike. I will put that info in my file.
