Dana 60 fluid capacity with Jeg's Aluminum cover??? #934996
02/22/11 05:37 PM
02/22/11 05:37 PM
Penna
70satelliteguy Offline OP
Penna
I am changing fluid and need to know how much of this Mobil 1 synthetic fluid to add? I think it is around 2-1/2 qts. but I don't want to overfill it and make a mess!
Thanks Mike
P.S. What a pain in the drain this is to do on the floor of your garage on your back and with wheelie bars in the way!!!
Re: Dana 60 fluid capacity with Jeg's Aluminum cover??? [Re: 70satelliteguy] #934997
02/22/11 05:59 PM
02/22/11 05:59 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
If there's not a "fill-to" plug on the back:
Lay your previous (stock?) cover down & fill it with water. Pour that amount into the Jeg's cover. Then take a large measuring cup, fill it to a specific level, and add to your existing level. That's the difference for the whole cover. If the oil level of your old cover was 1/2 or 1/3 up the inside, reduce your calculation of the difference accordingly.
If there is a fill-to plug, it's pretty much a no-brainer.
Re: Dana 60 fluid capacity with Jeg's Aluminum cover??? [Re: topside] #934998
02/22/11 08:59 PM
02/22/11 08:59 PM
Louisiana
K
kzinge1 Offline
kzinge1  Offline
K
Louisiana
I had the same problem. I just pumped fluid in it until it started to spill over alittle. Not too big of a mess, lol!
Re: Dana 60 fluid capacity with Jeg's Aluminum cover??? [Re: 70satelliteguy] #934999
02/22/11 09:52 PM
02/22/11 09:52 PM
ky
68roadrunner Offline
ky
2.5 on my girdle cover, but 2 is plenty for a drag car
Re: Dana 60 fluid capacity with Jeg's Aluminum cover??? [Re: 70satelliteguy] #935000
02/22/11 11:31 PM
02/22/11 11:31 PM
ohio
6440nssa Offline
6440nssa  Offline
ohio
ONE quart is all you need.
sean dornan
Re: Dana 60 fluid capacity with Jeg's Aluminum cover??? [Re: 6440nssa] #935001
02/22/11 11:35 PM
02/22/11 11:35 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I've never seen a cover that didn't have a fill hole,just fill it up till the lube runs out.
Re: Dana 60 fluid capacity with Jeg's Aluminum cover??? [Re: rowin4] #935002
02/23/11 12:45 PM
02/23/11 12:45 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Some aftermarket covers have the fill hole way to high to use as a "full mark".
My aluminum T/A cover with cap preload bolts is one of them... Not sure about the Jegs cover.
