dumb NOS ?? #934964
02/22/11 03:33 PM
02/22/11 03:33 PM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
about the bottles.
Are some bottles "lay down" style while others are "stand up" ??
If so, how can you tell them apart.
Can a lay down bottle be stood up and vice versa.
thanks!
Re: dumb NOS ?? [Re: MegaDart] #934965
02/22/11 03:51 PM
02/22/11 03:51 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
The bottles have a pickup tube which has a slight bend to reach the bottom corner of the bottle. This helps to insure the pickup is always submerged in liquid N.O.S.. When bottles are mounted tilted (laying down) the tube should be pointing down and to the rear of the car.
To answer your question, the bottles can be used either way UNLESS someone has modified the pickup (not likely)
Re: dumb NOS ?? [Re: ProStDodge] #934966
02/22/11 03:59 PM
02/22/11 03:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is it always bent towards the threads on the valve
(stock bottle).... so you should have the threads
pointed downward.... while the bottle is angled
Re: dumb NOS ?? [Re: MR_P_BODY] #934967
02/22/11 04:14 PM
02/22/11 04:14 PM
GA
Boosted Offline
Boosted  Offline
GA
or to the rear if they are standing up!
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: dumb NOS ?? [Re: Boosted] #934968
02/22/11 05:55 PM
02/22/11 05:55 PM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
thanks guys, exactly what I needed to know!
Re: dumb NOS ?? [Re: Boosted] #934969
02/22/11 05:57 PM
02/22/11 05:57 PM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
would it really matter?? I would not run a bottle less then 20#??
