Whats Going On With My Fuel Pressure? #934831
02/22/11 09:06 AM
02/22/11 09:06 AM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline OP
I just finished completely R&Ring the fuel system on my Coronet. New tank, pickup, fuel lines, pump, filter and rebuilt and deep cleaned the carb (a Street Avenger 875)
Problem is Im getting terribly low fuel pressure. I dont have a psi guage but when you get on it, the car stumbles and sputters and its not pulling enough vacuum to even fill up the (see-thru) fuel filter. It idles just fine and if I feather the throttle enough it will pull enough fuel through. But when its running, its just spurting through the filter. I pulled the rechecked the pump to make sure it was sitting on the pushrod correctly and it was OK. I also checked all the fuel lines. I richened up the mixture as much I could to see if that would help with fuel delivery and it didnt really make any difference.
The pump is a NAPA replacement part for a Hemi, which I figured would be substantial enough to feed my 875.
Re: Whats Going On With My Fuel Pressure? [Re: RangerDan440] #934832
02/22/11 09:14 AM
02/22/11 09:14 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Could be a bad fuel pump rod the new ones are soft and mushroom that or you got a bad fuel pump.
Re: Whats Going On With My Fuel Pressure? [Re: RangerDan440] #934833
02/22/11 09:17 AM
02/22/11 09:17 AM
vac leak or accel pump prob
Re: Whats Going On With My Fuel Pressure? [Re: RapidRobert] #934834
02/22/11 09:50 AM
02/22/11 09:50 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Is the tank vented through the cap?
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Whats Going On With My Fuel Pressure? [Re: RangerDan440] #934835
02/22/11 09:51 AM
02/22/11 09:51 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
can you put the old pump back on and see if it can draw fuel? it's possible the new pickup is constricted. is the lenght of the fuel pump rod the same as the old one? is the reach of the fuel pump arm and travel distance the same?
Re: Whats Going On With My Fuel Pressure? [Re: mikemee1331] #934836
02/22/11 10:37 AM
02/22/11 10:37 AM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
check fuel pump pressure and volumn at idle and 2500 rpm.
Re: Whats Going On With My Fuel Pressure? [Re: RangerDan440] #934837
02/22/11 12:55 PM
02/22/11 12:55 PM
Hampden, Maine
Procommuter Offline
super street
Procommuter  Offline
super street
Hampden, Maine
Some of the aftermarket sock filters that slide onto the fuel pick-up inside the tank go on to far. That blocks the end of the pick-up because it is up against the inside of the sock. If you find that this is your trouble just cut the end of your pick-up tube off at a 45° angle.
Wes 73 Barracuda 440 EFI 4 speed, 144.85 MPH LTA A/FSS Record Holder.
Re: Whats Going On With My Fuel Pressure? [Re: RangerDan440] #934838
02/22/11 08:58 PM
02/22/11 08:58 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Crack the gas cap loose to make sure the tank and/or the cap is breathing properly. A sealed tank will lead to no fuel pressure, especially when using the stock fuel pump. It may run okay on a cold start, then get progressivly worse fuel pressure as vacuum builds in the tank.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Whats Going On With My Fuel Pressure? [Re: GO_Fish] #934839
02/22/11 09:32 PM
02/22/11 09:32 PM
thanks for the replies guys, much appreciated
It was too cold to do anything on the car today.
the tank is vented through a tube at the front and not the cap (its a 1968 Coronet with a pre-EEC tank) Im wondering since I havent filled it with a full tank of gas yet (only about 5 gallons to get it running) would that have anything to do with pressure build up inside the tank? Ive replaced tanks before and never had a fuel psi problem.
I think I'll try and run it without the gas cap and see what happens. I just feel like the problem is in the tank.
Ive tried 2 other pumps on it-a stock 440 pump and a Holley HP one and Im still not getting the psi I need.
How about the power valve or accelerator pump?
Re: Whats Going On With My Fuel Pressure? [Re: RangerDan440] #934840
02/22/11 09:44 PM
02/22/11 09:44 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
check that pickup for good flow................i think you are on the right track
Re: Whats Going On With My Fuel Pressure? [Re: mikemee1331] #934841
02/22/11 09:57 PM
02/22/11 09:57 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Can you temporarily run the car off a jerry can connected to the fuel pump?
Might be able to trace it by eliminating the rest of the system.
